4'' exhaust install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 02-19-2009, 11:33 PM Thread Starter
brandon
bcangelo's Avatar
4'' exhaust install
how hard is it to install a 4'' exhaust. no one around here will do it for less than 300 and that is my mechanic who took the engine out of my wife's car and put it back for 300. wondering if i could do it effectively. i not a pro mechanic but i have pulled trannys and engines on older cars, do you think i can do it without serious mods to the truck
2002 f-250 7.3 ex cab automatic, 4'' turbo back magnaflow exhaust. tonneau cover. SOLD
2011 f-250 6.7 Lariat fx4 with lots of extras!!Sold
2011 Screw Ecoboost 4x4 with ALL the options
Excuses are like butts, everybody got one and they all stink!
bcangelo is offline
post #2 of 12 (permalink) Old 02-19-2009, 11:37 PM
Joedog's Avatar
Re: 4'' exhaust install
If you cant install your own exhaust, then you have no business working on anything else....sorry, but true.
2000 F-250 Supercab/Shortbed 6-speed
Swamp Ass Hybrids, Swamp Ass tuning, Stage 1 Oil, 38R, Southbend Clutch.
Joedog is offline
post #3 of 12 (permalink) Old 02-19-2009, 11:42 PM Thread Starter
brandon
bcangelo's Avatar
you know i just wanted to know before it started tearing into it and find out what i might have to modify anything like the firewall or anything. i know i can do it but wanted to know how difficult it is.
bcangelo is offline
post #4 of 12 (permalink) Old 02-20-2009, 12:27 AM
splitshot's Avatar
exhaust isnt hard at all, either get a sawzall to cut the old exhaust or you need to remove the tranny crossmember to get the one peice exhaust out. all the new ones Ive done come in peices so you dont have to remove the trans x-member. should take about an hour depending if you sawzall it and what rusted bolts you fight.
splitshot is offline
post #5 of 12 (permalink) Old 02-20-2009, 01:42 AM
<-- GO BRONCOS
dblamp's Avatar
Toughest part is removing the stock downpipe, after that its just putting the pieces together.... and getting the clamp off of the turbo.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #6 of 12 (permalink) Old 02-20-2009, 01:59 AM
War Pig
Caballo Diablo's Avatar
I used an angle grinder. hardest part was getting the v-band off of the back of the turbo.
Chad
04 F350, CC, LB, 4X4 Fat Bottom Girl....Butt A$$ Stock
SOLD>>>'00 F250, DP-Tuner, 5" Straight Pipe, S&B intake, autometer, Racer X TC and VB, Full Force Stage 1, prepump/in-tank mod, Annihilator, 203*
ET: 5.024 250' Mud Track
Caballo Diablo is offline
post #7 of 12 (permalink) Old 02-20-2009, 03:13 AM Thread Starter
brandon
bcangelo's Avatar
thanks guy for the insight, i appreciate it
bcangelo is offline
post #8 of 12 (permalink) Old 02-20-2009, 08:20 PM
Well Hung Member
stroked's Avatar
to disconnect the down pipe get you a can of pb blaster, and soak it before you start. when you get it loose, open up the clamp how you can, and squirt it down into the clamp, and get it to unseize from the turbo outlet, thats the biggest pain about exhaust install, and yea if you dont care about your stock exhaust(which will neevvver go back on), cut it in sections and throw it in the scrap pile
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #9 of 12 (permalink) Old 02-20-2009, 09:20 PM
<----My last CT scan
Motownfire's Avatar
It's easy. Took me about two hours starting with tearing out the old exhaust to installing the new exhaust. The longest part was when I got my dad to lay on the creeper and hold up on the new 4" downpipe while I got the band clamp around it and the turbo. No special tools required.
Motownfire is offline
post #10 of 12 (permalink) Old 02-20-2009, 11:57 PM
Layson's Avatar
It is easy...
Layson is offline
