Hybrids or HPOP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 02-19-2009, 03:16 PM Thread Starter
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
Hybrids or HPOP
Hey guys,
I am in a dilemma right now on what I want to do. I am really looking into Diesel-Sites adrenaline pump for my stage 1 injectors. My question is should I go ahead and get the pump right now or wait and get hybrids from Swamps and not worry about a HPOP? Thanks for any input.
Reuben
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
post #2 of 31 (permalink) Old 02-19-2009, 03:25 PM
fbilly420's Avatar
Re: Hybrids or HPOP
Are you looking for the truck in your sig. the 95'?
I would assume you still have the factory 15* hpop. I would probably go for the Adrenaline if it was me. But if you have upgraded to the 17* pump I would go for the hybrids.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #3 of 31 (permalink) Old 02-19-2009, 03:26 PM
Smarty Power!
John_DeereGreen's Avatar
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
Re: Hybrids or HPOP
If I were in your shoes, I'd get the hybrids, given you have the supporting mods for them, or can have Tony tune them down.
Jarrett Matthew
04.5 QCSB auto common rail
Smarty TnT; ISSPRO PERFORMAX
Suncoast full billet
John_DeereGreen is offline
post #4 of 31 (permalink) Old 02-19-2009, 03:35 PM Thread Starter
6.4's are my Hero.
Reubine's Avatar
Re: Hybrids or HPOP
Yes truck in sig and yes stock *15 pump. I do need something along the lines of a HPOP b/c I run these things out of oil.
Reubine is offline
post #5 of 31 (permalink) Old 02-19-2009, 03:36 PM Thread Starter
6.4's are my Hero.
Reubine's Avatar
Re: Hybrids or HPOP
If I am getting Swamps injectors I will have them tune them also. I don't have headstuds yet either so that would be a problem.
Reubine is offline
post #6 of 31 (permalink) Old 02-19-2009, 04:09 PM
secondarychaos's Avatar
Re: Hybrids or HPOP
Hybrids and tune them down FTW.
then you can get the pump later
Edit: the Injectors you have now will use roughly 1170cc's of oil to empty (assuming 160cc's) and 230cc hybrids will take 1150 cc's (roughly). the hybrids will empty a little faster, and will like higher ICP.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #7 of 31 (permalink) Old 02-19-2009, 05:10 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Hybrids or HPOP
Hybrids... Best bang for your buck!
Joe
CSIPSD is offline
post #8 of 31 (permalink) Old 02-19-2009, 06:00 PM
Re: Hybrids or HPOP
I loved my hybrids and loved them even more when i put my hpop on. They seemed to tow better and the truck was smoother with the hpop even though they aren't supposed to need a hpop.
speediseverything is offline
post #9 of 31 (permalink) Old 02-19-2009, 06:06 PM
dzljon's Avatar
Re: Hybrids or HPOP
I vote for the hybrids, and wait till you can get either a terminator pump or stealth. I am not totally sold on the fast of what dieselsite is trying to do,the stocker is still a very little houseing and will only move so much vollume modded or not.
99.5 F250/ VGT 5.9 CR Cummins4 link front and rear air ride
dzljon is offline
post #10 of 31 (permalink) Old 02-19-2009, 07:06 PM
Turbo99's Avatar
Re: Hybrids or HPOP
Did any one care to READ his post and see that he runs out of oil w/ stage 1's.....uh if that is the case then he prolly has a pretty week pump and it will do nearly the same w/ hybrids.........so he might need to get a pump, then save money for hybrids and look to sell his stage 1's.
_____________________________________________
Jeremy
08'F250 CCSB 4x4 ALL White except whats Black!!
10' Camaro 2SS LS3 All White except whats Black!! Supercharged 682 RWHP 10.80 @ 131mph
Turbo99 is offline
