Best Turbo? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 42 (permalink) Old 02-18-2009, 05:06 PM Thread Starter
PSN Pretender
907DAVE's Avatar
Best Turbo?
What turbo would be best for some 230 hybrids? I am looking for a turbo that can be used for a DD / towing and still be able to clean up hybrids in a race setting? Also looking for a turbo that can be upgraded in the future for larger injectors.
907DAVE is offline
post #2 of 42 (permalink) Old 02-18-2009, 05:11 PM
Good Times
Jake N's Avatar
Re: Best Turbo?
h2e and then you can mod it later.
2003 Cummins
2012 Cummins
Jake N is offline
post #3 of 42 (permalink) Old 02-18-2009, 05:18 PM
lildevil02's Avatar
Send a message via AIM to lildevil02
Re: Best Turbo?
I'd side 38R by far the fastest spooling drop-in turbo, I run it with DI mini-me's and its a blast to drive.
lildevil02 is offline
post #4 of 42 (permalink) Old 02-18-2009, 05:22 PM
Good Times
Jake N's Avatar
Re: Best Turbo?
True the 38r rocks but if he wants a turbo to upgrade later than the H2E is going to let him do that as the 38r won't
2003 Cummins
2012 Cummins
Jake N is offline
post #5 of 42 (permalink) Old 02-18-2009, 05:33 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Best Turbo?
H2e... Unless you want to upgrade to twins later...
Joe
CSIPSD is offline
post #6 of 42 (permalink) Old 02-18-2009, 05:34 PM
Re: Best Turbo?
OR 38R and some nitrous later....
Multiple ways to skin this cat for sure....
mattr66 is offline
post #7 of 42 (permalink) Old 02-18-2009, 05:57 PM Thread Starter
PSN Pretender
907DAVE's Avatar
Re: Best Turbo?
Would the h2e be large enough to clean up hybrids?
What size injectors will the modded h2e support?
907DAVE is offline
post #8 of 42 (permalink) Old 02-18-2009, 06:46 PM
secondarychaos's Avatar
Re: Best Turbo?
Sorry for the off topic post, but are you actually in North Pole, Alaska?
I stopped by there in my alaskan roadtrip...
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #9 of 42 (permalink) Old 02-18-2009, 06:50 PM
Banned
Re: Best Turbo?
What's your definition of "clean" for a 230ish cc hybrid?
Crystal clean I was not able to do under about 60lbs of boost with the compounds on the 250's. That is, when running WOT and actually emptying them. And if you do truly "clean" them, expect 550hp minimum.
Charles is offline
post #10 of 42 (permalink) Old 02-18-2009, 07:15 PM Thread Starter
PSN Pretender
907DAVE's Avatar
Re: Best Turbo?
Yup.. North pole
907DAVE is offline
