Plastiguage procedures - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 02-18-2009, 04:35 AM Thread Starter
Subject Matter Expert
PowerstrokeJunkie's Avatar
I am building a forged-rod engine for a buddy now, a safe reliable 450hp daily driver setup, and as we were tearing the junkyard engine apart tonight (which was in suprisingly CLEAN shape!), we plastiguaged the mains and rods. The mains were all .003, and the rods were between .001, and .0015. My question is this: I know the rod bearing/crank measurement is somewhere between .018 and .045" for oil clearance, and the plastiguage showed .015. Is that measurement from the plastiguage one-half of the clearance, as in there is also .015" clearance on the opposite side of the crank too, or does that force just squish the crank into the rod bearing, and there is only .015 oil clearance?
The mains, same thing. This time it was .003 instead. We are getting new coated rod bearings because a few look iffy, the mains look damn nice, near new. TIA
Stock
PowerstrokeJunkie is offline
post #2 of 31 (permalink) Old 02-18-2009, 08:18 PM
Plays with Motors
Machinist's Avatar
Re: Plastiguage procedures
I don't use plastiguage, don't recomend it, and don't trust it.
That being said, the number you got is supposed to be the true clearance, not only 1/2 of it.
Dial bore guage and micrometers is the only right way to measure clearances.
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #3 of 31 (permalink) Old 02-18-2009, 10:51 PM
throttle jockey by trade
hookin78's Avatar
2000 F-350 six speed
2000 F-350 automatic (custom tree dent mod)
1978 F-350 4speed 460 pulling truck
hookin78 is offline
post #4 of 31 (permalink) Old 02-18-2009, 11:19 PM
Binder man's Avatar
but what if your bore gauge and calipers are off?
Early 99, regular cab, Six Speed, Wildman Tuned, Red wastegate line MIA, muffler MIA, Isspro EGT/Boost, DIY Tymar, EBPV Switch, a slipping South Bend, 2.5" leveling kit, 35x12.5 BFG All-Terrains, 16.5" American Racing wheels SOLD
04, red regular cab, six speed, Edge SOLD
97, silver regular cab 300/200 s300
Binder man is offline
post #5 of 31 (permalink) Old 02-18-2009, 11:22 PM
PHPDiesel's Avatar
A tape measure will usually get you close enough...
Cody
PHPDiesel is offline
post #6 of 31 (permalink) Old 02-18-2009, 11:25 PM
Binder man's Avatar
I don't think I would feel safe taking a tape measure to measure something that is suppose to be in the thousandths.
post #7 of 31 (permalink) Old 02-18-2009, 11:30 PM
Caption This
444-4D's Avatar
You could use a yard stick. But don't ever let it get wet or it will lose it's accuracy. Actually plastigauge works fairly well if you understand how to use it. Rods are difficult to do because you have to hold them one direction while you bolt the cap on. It's easier if you have a helper. Mains are easier if the engine is upside down. If it is still in the vehicle then they get tougher.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #8 of 31 (permalink) Old 02-18-2009, 11:39 PM
you want some of this?
smorris's Avatar
A good length of rope works for me. long as they are all the same its okay , right??lol
I hope those numbers were off by a 0.
Cause .018, and .045 is a bit on the high side.
Thats enough clearance for a 15 inch journal with aluminum bearings. Not that a ford ever had an enigne with 15" journals, but Im just sayin.
Honestly the clearances sounded pretty good to me.
Plastigauge aint rocket science, but hey , we aint building a rocket now are we.
It may not be perfect, but it at least tells you you are in the ballpark. Since I've worked at my current job for the last 15 years, I've seen some crazy stuff, lemme tell ya, engines are WAY more forgiving than you would think.
Unless your right on the ragged edge, it should be fine.
Besides, international put that one together, and it it looks good after all those miles, then its probly okay.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #9 of 31 (permalink) Old 02-18-2009, 11:40 PM
smorris's Avatar
you're joking......right??
Ya know they werent serious?
smorris is offline
post #10 of 31 (permalink) Old 02-18-2009, 11:48 PM
Binder man's Avatar
As bad as I'd like to say I knew they were joking, I didn't. I have seen some pretty crazy #### though so you never know.
