does size matter...exhaust? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 02-18-2009, 04:28 AM Thread Starter
brandon
bcangelo's Avatar
Looking into changing an exhaust on a 7.3 automatic and I have had guys trying to sell me a 5 inch exhaust instead of a 4. I think the 4 is all I need. What say ye?
bcangelo is offline
post #2 of 24 (permalink) Old 02-18-2009, 04:31 AM
Send a message via AIM to JohnT
Re: does size matter...exhaust?
Don't waste your money on 5".
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #3 of 24 (permalink) Old 02-18-2009, 04:31 AM
psdmike's Avatar
4" is probly all you need but if you can go 5" why not.
1997 F350 Crew Cab, 7.3, 4x4, 5SP Short Shift kit, 5" RSK SD V Code springs, DIY Intake, 5" Exhaust with 30" FTE Resinator, intercooled, TS chip.
psdmike is offline
post #4 of 24 (permalink) Old 02-18-2009, 04:32 AM
09 6.4
webb06's Avatar
it just depends on what you are wanting to do with ur truck. if you are just wanting to put a few mods on it then 4" will do but if u are wanting to go full out then you will probably want a 5". a 5" will probably have a deeper drone. but i have a 4" on my 7.3 and it sounds great
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #5 of 24 (permalink) Old 02-18-2009, 04:35 AM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
I had 5" on 2 of my trucks and just recently did 4" because 5" is in the way, whether you run regular exhaust or stacks. 4" is all you need, just ask the 600hp cummins guys.
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #6 of 24 (permalink) Old 02-18-2009, 04:38 AM Thread Starter
brandon
bcangelo's Avatar
i use this truck as my everyday driver, not to hard on the foot feed. how has the larger system done overall than stock?
bcangelo is offline
post #7 of 24 (permalink) Old 02-18-2009, 04:55 AM
Banned
My 4" exhaust doesn't seem to be any problem at 600hp. Although who knows. Maybe I'd pick up a couple hundred horsepower with a 5"?
Charles is offline
post #8 of 24 (permalink) Old 02-18-2009, 05:09 AM
secondarychaos's Avatar
Over stock- you'll definately see quicker spool, and it'll run better on the upper end... Lower backpressure for the same boost. (assuming you have a newer truck with a wastegate)
Also, a few guys have made over 600 hp on a 3" downpipe (Largest that's easily fit in an OBS) ...
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #9 of 24 (permalink) Old 02-18-2009, 05:16 AM
have 97 obs made jump to 3 down 4 out made big dif. size does matter here
mowrus is offline
post #10 of 24 (permalink) Old 02-18-2009, 06:01 AM
ford_trck's Avatar
I had 4in on my 02 and I thought it sounded good, I got 5in because nobody around here had it and sounds wise I definatly love the sound so much more. Performance wise I doubt there is a difference.
Early 99 F-350 CC LB 6-speed
Turbo, injectors, fuel, clutch, nothing special
Originally Posted by Thuglike View Post
Anyone who stands to pee drives a 7.3.
Originally Posted by HeWhoIs View Post
The only brutha you know is the one that's bangin your little sister you cracka.
ford_trck is offline
