do I need a bigger hpop with stage 1's? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-17-2009, 11:55 PM Thread Starter
"Smoke A Lil Smoke"
chappy's Avatar
I have done lots of reading and it looks like with stage 2's I could benefit from a bigger hpop but I couldn't find a definent answer for stage 1's.I realize that stage 1 single shots ,which I bought ,require less oil then splits but will I be ok.I just want to get it all around before I get a chip burnt so I don't have to keep reburning it.I have an early 99 so of course,I have the smaller 15* pump with 265,000 miles on it.With my stock AB injectors and the edge evolution,it would fall flat on its face when it got to higher rpms so I know the pump was struggling.Just don't want it to do it as bad with the stage 1's single shots I got.
2004 f250 egr delete,studded,fass 95,suncoast convertor,itp RR,Banks intercooler,58v tuned ficm,Powermax turbo,Matts tunes,6in Icon and 35 toyos 20x12 fuels
Early 99 exlb 4wd-SOLD All Shaeffer oil
Will Iott -8/24/84-7/4/10 "We miss you buddy"
chappy is offline
post #2 of 10 (permalink) Old 02-18-2009, 12:57 AM
<-- it's like that
Re: do I need a bigger hpop with stage 1's?
It won't be as bad as the AB's, but it's doubtful you'll reach "optimum" oil pressue with a 15 degree pump.
I'll let you decide what optimum oil pressure is, since that's always a debated subject.
Still, if I were you I'd go ahead and throw the injectors in.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #3 of 10 (permalink) Old 02-18-2009, 01:00 AM
throttle jockey by trade
hookin78's Avatar
You may look into the Adrenaline pump from Diesel Site, not a great big pump but bigger than stock 17 deg. and cheaper than one from ford, with the same warranty.......Just food for thought. Oh...Its only $469.00 .
2000 F-350 six speed
2000 F-350 automatic (custom tree dent mod)
1978 F-350 4speed 460 pulling truck
hookin78 is offline
post #4 of 10 (permalink) Old 02-18-2009, 01:37 AM
Turbo99's Avatar
_____________________________________________
Jeremy
08'F250 CCSB 4x4 ALL White except whats Black!!
10' Camaro 2SS LS3 All White except whats Black!! Supercharged 682 RWHP 10.80 @ 131mph
Turbo99 is offline
post #5 of 10 (permalink) Old 02-18-2009, 01:39 AM Thread Starter
"Smoke A Lil Smoke"
chappy's Avatar
Thats what I was thinking about .Thats why I asked.I'm still learning a lot but at least I am reading and actually learning.6 months ago I wouldn't even know what a hpop did.That adrenaline pump looks awesome but if I don't need it,then I won't waste my time.
chappy is offline
post #6 of 10 (permalink) Old 02-18-2009, 01:41 AM Thread Starter
"Smoke A Lil Smoke"
chappy's Avatar
I waa thinking the same thing,it wouldn't be as bad but I won't reach optimum oil pressure either.We'll have to see then if the quad sell this weekend and then I can get it before I get the injectors put in and tunes or not.
chappy is offline
post #7 of 10 (permalink) Old 02-18-2009, 01:45 AM
Turbo99's Avatar
If you truck does what you said....it needs a new pump, and as said above the Adrenaline is cheaper than a new 1.
Jeremy
Turbo99 is offline
post #8 of 10 (permalink) Old 02-18-2009, 01:53 AM Thread Starter
"Smoke A Lil Smoke"
chappy's Avatar
If I would have changed my top end oil,it would have held up better
chappy is offline
post #9 of 10 (permalink) Old 02-18-2009, 02:57 AM
hookin78's Avatar
hookin78 is offline
post #10 of 10 (permalink) Old 02-28-2009, 07:29 PM Thread Starter
"Smoke A Lil Smoke"
chappy's Avatar
Well I got them in and yeh,I need a bigger hpop.It runs out once your getting on it good and throws a 1209 code which I guess means ICP malfunction.I am going to drop the tank and do that mod with the parts I got from David.Maybe I'm just mainly running out of fuel for all I know.I am gonna try to throw a helper pump in line before the fuel pump also and see if that helps for now.
chappy is offline
