Boost ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-17-2009, 03:28 AM Thread Starter
Boost ?
Anytime I am in it WOT, when the trans changes gears. I get turbo stall and fart bad. what is causing this and what can I do to fix. I go from 33psi to 10psi on 2-3 shift
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
Torque37 is offline
post #2 of 10 (permalink) Old 02-17-2009, 03:57 AM
Ticking time bomb
Re: Boost ?
surging.. put a 1.15 housing on your 38r
groomzybanshe is offline
post #3 of 10 (permalink) Old 02-17-2009, 04:09 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Boost ?
1.15 housing... The only way it should be sold...
Joe
CSIPSD is offline
post #4 of 10 (permalink) Old 02-17-2009, 10:42 AM Thread Starter
Re: Boost ?
I did not think my issue was surge?
Torque37 is offline
post #5 of 10 (permalink) Old 02-17-2009, 06:34 PM
secondarychaos's Avatar
Re: Boost ?
Sounds like surge to me.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #6 of 10 (permalink) Old 02-17-2009, 07:25 PM
The Fireman
big_stroker's Avatar
Re: Boost ?
Sounds like a surge... why dont ya take a video
big_stroker is offline
post #7 of 10 (permalink) Old 02-17-2009, 08:38 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
Re: Boost ?
i thought that was stall not surge
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #8 of 10 (permalink) Old 02-17-2009, 11:22 PM
<-- GO BRONCOS
dblamp's Avatar
Re: Boost ?
Surge happens while towing, stall happens on a shift. Stall is just the extra air exiting out through the air filter, when the engine RPMs drop from the shift.
I hope I explained that properly.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #9 of 10 (permalink) Old 02-18-2009, 01:07 AM Thread Starter
Re: Boost ?
Yes stall is what is going on not surge. It happens on every shift at WOT, Somtimes its bad enough to downshift right after it upshifted, because it chokes it out.
Torque37 is offline
post #10 of 10 (permalink) Old 02-18-2009, 01:10 AM
PSDfan99's Avatar
Re: Boost ?
My truck kind of does that too. I think chip tuning will fix it. I get some surging, but I know what you mean with the "choking out" after a shift.
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
