DIY Injector Success - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 02-15-2009, 10:09 PM Thread Starter
spb_2006's Avatar
Ive been looking at the DIY stage 3 hybrid injector kit and was wondering if anyone had done it and how it went? Also, Im planning on getting the 38R but it will be a while can i run this big of injectors on the stock turbo?
spb_2006 is offline
post #2 of 18 (permalink) Old 02-15-2009, 10:15 PM
That thing got a Cummins?
nasty96's Avatar
Re: DIY Injector Success
Diy injectors are easy to do. Just follow the very detailed directions, do only 1 injector at a time, and I highly recommend getting the injectors flowed before installing them in your truck. As for your stock turbo, you can run it with these injectors, but it won't like it. Any kind of pounding on the truck and you better plan on a rebuid kit for the turbo.
Ford makes it
, I break it
1996 F350 CCLB 4x4 Broke Built Auto
2000 Dodge 3500 5 Speed 4x4 450k and Counting
2001 Dodge 3500 6 speed 4x4 Fully loaded
nasty96 is offline
post #3 of 18 (permalink) Old 02-15-2009, 10:16 PM
urbanwheeler's Avatar
mine went very well, just find a nice clean spot and keep it clean while you are doing them. i have also been running a sd turbo with a ww for a few months now. egts are not really bad and im seeing 43psi of boost. its not much more to have jim do them for you.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #4 of 18 (permalink) Old 02-15-2009, 10:22 PM Thread Starter
spb_2006's Avatar
Whats it running to have Jim do it? Your making 43lbs of boost out of your stock turbo?
spb_2006 is offline
post #5 of 18 (permalink) Old 02-15-2009, 10:27 PM
nasty96's Avatar
43+lbs of boost + stock turbo=
Ford makes it
, I break it
nasty96 is offline
post #6 of 18 (permalink) Old 02-15-2009, 10:29 PM
Back to Civilian Life!!
MILFORD's Avatar
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #7 of 18 (permalink) Old 02-16-2009, 01:33 AM Thread Starter
spb_2006's Avatar
Thats what I thought...Does anyone know the difference in jim's price and what it is to do it yourself?
spb_2006 is offline
post #8 of 18 (permalink) Old 02-16-2009, 02:03 AM
I think it is plus 200
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
post #9 of 18 (permalink) Old 02-16-2009, 03:22 AM
madmaxz's Avatar
but you still have to get the pistons machined or buy them from jim for $225.
Rick
2002 F250 CC LB - 5" lift, BTS, 4.10s+trutrac, 250/100s, studs, pushrods, dual springs, ITP RR, 2 SD pumps, Beans plenums, Balanced, Blueprinted and cryod bottom, ported heads, GH 1.5 cam, 4" Exhaust, 6.0 trans cooler
OTW- S366/s483 compounds, 20x10 black hostages + 37 13.50 toyos, fresh BTS, Live tuning, And maybe an srp 1.1
madmaxz is offline
post #10 of 18 (permalink) Old 02-16-2009, 03:24 AM
That should be included in the price if you go the stage 3 route...
rpm-inc is offline
