formula for figuring compression?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-15-2009, 03:21 AM Thread Starter
Built By Me
444smoker's Avatar
Hey im just curious as to how exactly you go about figuring the compression ratio in a motor? i had my pistons worked over a little and would like to figure what im at. Do you have to figure the CCs of the bowl then use a formula to convert that to your compression ratio? Thanks
Robert
1996 Red OBS
Built Motor
DP Tuner
Garrett GT42
ARP Fasteners
Terminator HPOS
B-Codes
Crower rods
filled block
560hp
444smoker is offline
post #2 of 7 (permalink) Old 02-15-2009, 03:28 AM
Re: formula for figuring compression??
http://www.rbracing-rsr.com/compstaticcalc.html
Second one on a google search.
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
post #3 of 7 (permalink) Old 02-15-2009, 04:04 AM Thread Starter
Built By Me
444smoker's Avatar
thanks im right at about 16.5:1 ratio
1996 Red OBS
Built Motor
DP Tuner
Garrett GT42
ARP Fasteners
Terminator HPOS
B-Codes
Crower rods
filled block
560hp
post #4 of 7 (permalink) Old 02-15-2009, 04:35 AM
HP Junky
That should be just about perfect, it'll still start okay in the winter
RockinJW is offline
post #5 of 7 (permalink) Old 02-15-2009, 05:12 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
my 15:1's start just fine outside, cold in the winter. starts just as quick as stock, but the white smoke, err.
Stock
PowerstrokeJunkie is offline
post #6 of 7 (permalink) Old 02-15-2009, 07:52 AM
Plays with Motors
Machinist's Avatar
Miscalculation or an omission of the valve relief volume in the head, and the area above the top ring but below the crown can cause your numbers to be off by a full compression point. Those online calculators only give you part of the picture - the only way to truly calculate compression is by the swept volume vs compressed volume calculations involving actually taking cc measurements of the bowl, valve reliefs, calculating gasket volume, etc...
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #7 of 7 (permalink) Old 02-16-2009, 01:23 AM Thread Starter
Built By Me
444smoker's Avatar
I should be pretty close then, i found the cc in the bowls and took mesurements before i put it together, wrote it down on some paper i just didnt know how to calculate that into the compression ratio.
Robert
1996 Red OBS
Built Motor
DP Tuner
Garrett GT42
ARP Fasteners
Terminator HPOS
B-Codes
Crower rods
filled block
560hp
