What size? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-14-2009, 02:21 AM Thread Starter
What size?
I'm putting the bypass oil filter on, what size ends screw into the block and the filter base? bypass_hoses1.jpg
what size screws into the out to filter, and the return?
F-350 is offline
post #2 of 4 (permalink) Old 02-14-2009, 03:40 AM
Re: What size?
The hose on the left (oil cooler header, Supply to bypass) is 1/8 pipe and the one on the right (block, return passage) is either 1/4 pipe or 3/8 pipe I can't recall which.
Edit: after looking at my pictures of that I am sure the bigger one is 3/8 pipe
tjbeggs is offline
post #3 of 4 (permalink) Old 02-14-2009, 05:20 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: What size?
Be careful with the teflon tape and screwing in that fitting into the oil cooler header. Don't crack it, cause that sucks.
Stock
PowerstrokeJunkie is offline
post #4 of 4 (permalink) Old 02-14-2009, 06:57 PM Thread Starter
Re: What size?
OK thanks for the info everyone, I'll be careful
F-350 is offline
