Anyone remove the wastegate from there stock turbo? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 02-13-2009, 02:37 AM Thread Starter
i have a boost annilater that i got from jody and with it maxed out i can only boost like 22psi.. I have nothing done to my wastegate nor have i touched it.. I was just wondering what it would take for me to boost 28-30psi? I know people on here are boosting that much on a stock turdbo but how? Im using dp-tuner also.. Im not surging the turbo at all.. I have the wicked wheel installed. If i unhook the vacuum line from the wastegate what will that do? im going on the dyno soon and i would like to atleast hit 28psi..
02f250dp is offline
post #2 of 14 (permalink) Old 02-13-2009, 02:38 AM
Re: Anyone remove the wastegate from there stock turbo?
Stock turbo not going to last long at 28psi
F-350 is offline
post #3 of 14 (permalink) Old 02-13-2009, 02:39 AM
Super Hauler!
Super_Hauler's Avatar
If you unhook the waste gate line it will let you boost more beacuse it wont open the waste gate as early as it would with it hooked up.
Super_Hauler is offline
post #4 of 14 (permalink) Old 02-13-2009, 02:39 AM Thread Starter
i not really conserned about the turbo.. Im just trying to get the most out of it for the dyno..
02f250dp is offline
post #5 of 14 (permalink) Old 02-13-2009, 02:41 AM Thread Starter
would i have to block the vacuum line off?
02f250dp is offline
post #6 of 14 (permalink) Old 02-13-2009, 02:41 AM
More boost doesn't exactly mean more hp
F-350 is offline
post #7 of 14 (permalink) Old 02-13-2009, 02:42 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Crank the waste gate rod to stiffen up the spring,so it dont blow open so easily.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #8 of 14 (permalink) Old 02-13-2009, 02:44 AM Thread Starter
which way clockwise or counterclock wise??
02f250dp is offline
post #9 of 14 (permalink) Old 02-13-2009, 02:45 AM
I just pulled the red line off of the canister and it dangles. It will hit 30 psi if I push it hard enough, but I doubt that it is very useable air. I am sure that it is very hot air, being out of its map.
2003 7.3 XLT FX4, AFE Stage 2, Regulated Return, Bowl Delete, 3/8" line from tank to heads, Pre/Post Filters, Tank mods, DP F5: 60T, 80E, 120R, 6.0 IC, 6.0 Trans Cooler, Suncoast Shift Kit, Wicked Wheel, ITP Boost Annihilator, Di Procol Optix, Straight Pipe, CCV, 285/75/16 BFG AT's
breyrw is offline
post #10 of 14 (permalink) Old 02-13-2009, 02:47 AM
Banned
It's a pressure line, not vacuum. Most people just stick it over the end of the closest T-bolt on one of the boots right there at the intake spyder.
While I don't think it's possible to actually loose power by holding a wastegate closed on a truck, it will likely not make any serious power changes with your stock turbocharger. You'll get more heat than anything else.
Charles is offline
