hpop bowl spring - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 08-11-2013, 07:23 PM Thread Starter
powerstroke12's Avatar
hpop bowl spring
Has anyone seen or done the fuel bowl spring replacement with the stiffer spring? or shim the spring? how big of a difference does this make?
powerstroke12 is offline
post #2 of 6 (permalink) Old 08-11-2013, 07:35 PM
the stryker god
Re: hpop bowl spring
Wtf does the fuel bowl have to do with the hpop
bruce51d is offline
post #3 of 6 (permalink) Old 08-11-2013, 10:42 PM Thread Starter
my bad the fuel bowl spring not the hpop. you're worse than a female
post #4 of 6 (permalink) Old 08-12-2013, 03:10 PM
Figure out what your fuel pressure is first before you change it
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #5 of 6 (permalink) Old 08-12-2013, 04:04 PM
Village Idiot
southmike's Avatar
it makes a difference in an obs truck. here on a superduty you want it right around 62-64 psi. ie 50 is too low 80 too high .
southmike is offline
post #6 of 6 (permalink) Old 08-12-2013, 08:15 PM
Bobs 7.3
Bobs 7.3's Avatar
I put the blue spring in my 02 cause i resealed the bowl while it was off and the stocker had 170,000 miles on it but its good insurance i thought. Didnt really see any difference in running wise.
Bobs 7.3 is offline
