DD Friendly Anti-wrap Links - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 121 (permalink) Old 02-11-2009, 02:48 PM Thread Starter
Banned
A few people had asked me about these links and about getting pictures, so here are a few.
Those are just HREW "pipe" links with weld in bungs and greasable Johnny joints. It's a combination of a Heim and a poly joint that is fully rebuildable. They shouldn't wear out anywhere near as fast as a Heim, and they should not clink and clank like a heim.
I have less than 300 in the links. The brackets are Pro Comp. I think they can be had brand new for 150 or so.
Charles is offline
post #2 of 121 (permalink) Old 02-11-2009, 02:51 PM
The Fireman
big_stroker's Avatar
Re: DD Friendly Anti-wrap Links
Nice setup... I would like to build me something like that when i get the spare time.
big_stroker is offline
post #3 of 121 (permalink) Old 02-11-2009, 03:19 PM
Smarty Power!
John_DeereGreen's Avatar
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
Looks nice...and effective.
Jarrett Matthew
04.5 QCSB auto common rail
Smarty TnT; ISSPRO PERFORMAX
Suncoast full billet
John_DeereGreen is offline
post #4 of 121 (permalink) Old 02-11-2009, 03:38 PM
King Dingaling
TANK'S 250's Avatar
Those look real good man...nice job.
I did a video of mine,...before and after.....huge difference.
before bars:
after bars:
TANK'S 250 is offline
post #5 of 121 (permalink) Old 02-11-2009, 04:07 PM
Keyboard Thug
Big Bore's Avatar
Is it just me, or does it look like those arms will hit the spring hanger if the wheel is stuffed? Should they have a longer frame bracket to compensate?
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
Big Bore is offline
post #6 of 121 (permalink) Old 02-11-2009, 04:18 PM
Back to Civilian Life!!
MILFORD's Avatar
I was going to say the same if your pushing some weight in the bed or on a trailer do the springs hit the bar?
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #7 of 121 (permalink) Old 02-11-2009, 04:20 PM
secondarychaos's Avatar
Tank- nice videos man!
Charles- definately a nice setup. have you had to replace anything on them since you made them? looks like a sturdy, long-lasting design.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #8 of 121 (permalink) Old 02-11-2009, 04:25 PM
Turbo99's Avatar
I did those exact style on my 7.3 but I tried it w/ 1" and it bent the $hit out of them so I did them again out of tubing and then built gusetts and another tube on top to get it to work. I shoulda just used larger and stayed w/ a single bar like you did.
_____________________________________________
Jeremy
08'F250 CCSB 4x4 ALL White except whats Black!!
10' Camaro 2SS LS3 All White except whats Black!! Supercharged 682 RWHP 10.80 @ 131mph
Turbo99 is offline
post #9 of 121 (permalink) Old 02-11-2009, 04:34 PM
rebelchevy02's Avatar
I made a set for mine, out of .25 wall DOM, with possibly the same JJ's as you seem to have used (mine had 1.25 shank size, and 9/16 through bolt.) However, I made a set of brackets, that I welded to the front spring hangar, and welded to the axle. And then welded the axle tubes, to the pumpkin. I cycled the suspension (with our skid loader), before attatching the front bolt, and the way I did it, there was only about a 1/16" of forward, and rearward movement from were my hole was. Other then the fact theres no axlewrap now, there is absolutely no affect on ride. Basically turned the rear suspension into a 4 link, like youve (charles) always said about.
DRW and tow fast parts.......
rebelchevy02 is offline
post #10 of 121 (permalink) Old 02-11-2009, 04:52 PM
Failure to Communicate
highfive's Avatar
Charles, nice simple setup especially if it gets rid of the heim banging.
Sidetrack but what fuel filter setup do you run and how are those tires holding up?
96 F250 CC SB 4x4
DIY or Die Tryin-Fuel, Trans, Lifted and Stroked
highfive is offline
