How accurate are the OEM sensors? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-11-2009, 03:41 AM Thread Starter
rebelchevy02's Avatar
How reliable do you think the exhaust back pressure sensor, and map sensor are? Mainly in accuracy. Ive been thinking quite a bit about back pressure vs boost, (and no, I dont make any power) But Im about to replace the injectors with ACs, and possibly a gtp38r if necesary. Everyone seems to say the ratio of back pressure to boost gets high on the OEM turbo, but at 24 psi, pulling a trailer up a hill tonight, AE told me both were at 40psi (includeing the 14.7psi for ambient) And my mechanical boost gauge agreed, at 24psi. They both also agree with key on, engine off (ebps and map) Seems mostly its in a 1:1 ratio upto 24 psi (other then when initially spooling up). I didnt go above 24, because I dont have a map fooler, but are my results skewed information from the ODB port? The only mods to the turbo and exhaust would be the ATS housing, and HFO, and a 4 inch exhaust. Oppinions?
DRW and tow fast parts.......
rebelchevy02 is offline
post #2 of 6 (permalink) Old 02-11-2009, 01:29 PM Thread Starter
Re: How accurate are the OEM sensors?
22 views and nobody has an oppinion?
post #3 of 6 (permalink) Old 02-11-2009, 01:55 PM
My AE showed different readings than a scan tool. The AE readings seemed high, and the scan tool read the same as the gauge
99 F350 CCLB
skav is offline
post #4 of 6 (permalink) Old 02-11-2009, 04:28 PM Thread Starter
Im interested in knowing how they compare to someone who installed an external back pressure gauge, and a boost gauge (I obviously have a boost gauge) I just remember CSIPSD and a few others saying how excessive the exhaust back pressure was significantly higher then boost by almost two times, even at 25 psi. Is my truck a freak, or is the data Im getting skewed by the pcm, or is the location of the ebps bad for this data, or are the sensors just not that accurate in this region? The map seems to agree with my boost gauge. This is the main reason I ask, Im curious if the ebps is accurate.
post #5 of 6 (permalink) Old 02-11-2009, 09:08 PM
If both sensors are reading ambient pressure (~14.7 PSI) key on engine off then you can assume that they are reading correctly when under pressure. I think people routinely overstate the drive vs boost pressure differences.
Swamp is offline
post #6 of 6 (permalink) Old 02-12-2009, 12:44 AM Thread Starter
Well thats interesting enough. So maybe the stock turbo would do ok with AC's? I was pretty concerned about what other people had said about back pressure vs boost, but Im not seeing that. I know so many say how good the gtp38r is, but these results just made me kinda wonder. The truck will never be a racer, mainly looking for efficiency.
