6637 tubing for install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 08-07-2013, 11:58 PM Thread Starter
JJozwiak's Avatar
I just bought my 6637 air filter and outerwear pre filter. I called up my local auto parts stores to try and source a piece of 4inch exhaust tubing. This seems to be a bit harder to find than I thought. Nobody has just 4 inch od exhaust tubing laying around. Everybody has 4 inch id couplers.
Where have you guys found some tubing?
I went to the local NAPA and they said they could order it but the shortest piece they could get is 8 inches and it would cost 20 bucks. I thought that to be excessive so hopefully you guys can give me some direction!
JJozwiak is offline
post #2 of 13 (permalink) Old 08-08-2013, 01:25 AM
the stryker god
Re: 6637 tubing for install
Do you know anyone with exhaust on their trucks? They come with enough for a cclb so if the configuration is shorter they'll have some left over
bruce51d is offline
post #3 of 13 (permalink) Old 08-08-2013, 01:27 AM
Blackbullet73's Avatar
WLK-42247
just google that its a walker part number for 4in piece of pipe with 45* bend
1996 F250 SCLB 4x4 Built E4OD 4.10, napa 6637, 3" dp,3.5" delete pipe, 4" side pipe, TS 6 pos, switched ebpv
Blackbullet73 is offline
post #4 of 13 (permalink) Old 08-08-2013, 03:36 AM
Until you find a short piece of 4" tubing, you can use a 3 1/2" PVC connectir from the hardware store, The ID is a little smaller but it is a work around you can use. (That connector is 4" OD, same as the exhaust tubing)
Early 99 F-250 XLT Extended Cab 4x2. XLE4 PCM, BTS Transmission, pre pump fuel filter,CCV Mod, DIY TYMAR, Coolant Filter, 48 Gal Transfer Flow Mid-Ship Fuel Tank
FleetMan is offline
post #5 of 13 (permalink) Old 08-11-2013, 06:45 PM
I bought a chunk of 4 in tubing at my local NAPA. they sell in foot lengths for around $6.50
ford_shooter is offline
post #6 of 13 (permalink) Old 08-16-2013, 02:20 AM Thread Starter
JJozwiak's Avatar
Checked with the local NAPA and the smallest section they would sell me was 18 inches for 30 bucks. Went down the road to the Tuffy were I take my fire departments vehicles for service and he hooked me up with a 5 inch piece for FREE. Can't beat that deal.
Anyway I got my filter in the mail from Fleetfilter today and did the install. I snapped a couple pics.
JJozwiak is offline
post #7 of 13 (permalink) Old 08-16-2013, 04:22 AM
mikes95powerstroke's Avatar
A piece of intercooler piping off a tractor trailer truck will work well also. If you have any junk yards around.
Black truck. 350/200 S472sxe arp, beehives, pushrods, fuel lab pump, stealth twins, swamps idm. Dana60 with ox locker. 33 row dorman transmission cooler. BTS transmission. 20x12 mo970 305/55 toyo open country.
2011 f350 36xxx 20x12’s -44 leveled.
White. 230,xxx 1995 f250 Dana 60, 5inch diamond eye. 6637. Winter/work truck.
mikes95powerstroke is offline
post #8 of 13 (permalink) Old 08-16-2013, 02:11 PM
9755's Avatar
Some of the big chain dept stores have 4" conduit. Not sure on the price tho. I found the piece I needed for the filter install at the local muffler shop. Got a foot long piece for $5 from the scrap pile
9755 is offline
post #9 of 13 (permalink) Old 02-13-2015, 06:33 AM
found it!
Dynomax Performance 41987 - Walker Exhaust Pipe Connectors
http://www.summitracing.com
Just type in 41987 in the search field.
Just got my first diesel! 2001 Ford Excursion 7.3L 4x4 128K miles
First order of business.......give her some air!
SkyHigh05 is offline
post #10 of 13 (permalink) Old 02-13-2015, 11:42 PM
POWER Junkie
PSD POWER007's Avatar
Look on eBay for 4" intake pipe. I bought a 5" long aluminum intake pipe and it has the ribbed ends like an intercooler pipe. Was only like $14 shipped if I remember right.
I did use the 3.5" pvc for a bit. Used a die grinder and rounded the inlet edge for smoother flow.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
