need some tips for a truck pull - PowerStrokeNation : Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 21 (permalink) Old 08-06-2013, 11:42 PM Thread Starter
hi i am entering my first truck pull in a couple weeks at the local fair. i have never pulled before. my truck has 3 inch lift nappa 6637 filter straight pipe and sct programmer. i was wondering if i could get some tips. i have a auto trans. im not sure if i should start out in drive 1st 2nd or what and if i should have it in four low or hi and anything else that would help thanks
early 99 powerstroke ext cab long bed lariat. auto trans. 2 inch shackle lift. napa air filter mod. sct tuner with custom tunes from innovative
early 99 powerstroke is offline
post #2 of 21 (permalink) Old 08-07-2013, 12:01 AM
dsberman94's Avatar
Re: need some tips for a truck pull
I used 4 low second. 4 low third would be ideal but impossible for these auto trucks. I dont floor it right off the line. I usually go about 1/4 - 1/3 throttle to start until some momentum is built up then floor it and hold it till the flag guy tells you to stop unless you're getting really bad wheel hop then let off some to stop the hop and get back into it. Also memorize a dummy list because you will be so nervous/excited you'll probably forget something. Try to max out your weight for your class by putting stuff in the bed and tying it down. You would be in work stock class so check your events rules before you go. The only way to really learn your own way is by doing it. Everyone does something's different.
02
F250 7.3 Crew Cab Short Bed Lariat
4"dp 5 inch pipes to dual 8 inch stacks (summer)
4" turbo back dual axle dumps (winter)
PHP Hydra (loaded)
Edge insight CTS monitor w/ eas system
17 ton d-ring with solid polished titanium hitch
80% over rosewood injectors
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
dsberman94 is offline
post #3 of 21 (permalink) Old 08-08-2013, 11:31 PM Thread Starter
ok thanks dsberman94 do you think i should hold the break and build boost up then go? and the only rules i know of is you cant have your front end tied down and no weights upfront and you cant exceed 8500lbs
post #4 of 21 (permalink) Old 08-09-2013, 12:41 AM
jtgf250's Avatar
No don't build it up on a stock class and Trans. Do as he said. Just get the truck moving and then let her eat.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #5 of 21 (permalink) Old 08-09-2013, 12:42 AM
the stryker god
You're gonna get embarrassed, I suggest you just watch
bruce51d is offline
post #6 of 21 (permalink) Old 08-09-2013, 12:47 AM
dsberman94's Avatar
if you had a built trans then you could build it a little but definitely not on a stock trans. even if your nowhere near the top of the board just have fun. dont take #### from other people seriously. its obviously your first pull anyway so just have fun. everyone has to start somewhere and sometime.
02
PHP Hydra (loaded)
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
post #7 of 21 (permalink) Old 08-09-2013, 01:10 AM
Village Idiot
southmike's Avatar
there may be some truth to this...
but also go to powerstroke army and ask..there are a few pullers I know over there.
southmike is offline
post #8 of 21 (permalink) Old 08-09-2013, 12:25 PM Thread Starter
ya i know ill get embarrased i just wanted to do it for fun i know i wont get anywheres near a full pull just wanna see what the truck can do
post #9 of 21 (permalink) Old 08-09-2013, 12:28 PM Thread Starter
i also have a sled pull tune from innovative diesel that locks the torque converter in that i am going to use to
post #10 of 21 (permalink) Old 08-09-2013, 12:33 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Dont be an ass... I pulled my first sled in a bone stock 97... It was fun...
You might be supprised. Every class and weight is set up differant as to how the weight slides...
4 low, 2 gear...
Lift if you hop, other wise enjoy.
If you can easily block the rear so it cant sag. You can use some 2x2 metal tubing pretty easy.
Joe
CSIPSD is offline
Closed Thread
