DIY Fuel System - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-10-2009, 04:13 PM Thread Starter
Busy Busy
Marty's Avatar
DIY Fuel System
Well the truck is in the shop and I've had some time to think. I currently have dual stock pumps which held up just fine with the hybrid injectors. I'm thinking I'll need to retest pressures with these bigger injectors. I'll probably need to increase volume.
Here is what I was thinking.
5/8" pickup tube to 3/8" fuel line forward. There are 2 variances here so that's the first question.
1. 3/8" line to a air/water seperator, 3/8" line to a stock fuel pump, 3/8" line to 2 micron filter, 3/8" line to another stock fuel pump, 3/8" line up to heads.
or option 2.
2. 3/8" line to fuel/water seperator and 2 micron filter. Use dual outlet filter block or my current "T" and then run both stock pumps in parallel on 5/16" lines until they "T" back into one and then run 3/8" from there up to the heads.
After I decide how to configure that with plans of upgrading one of the pumps in the future, I need to decide on which fuel regulator to get.
I had the Aeromotive A11000-6 or the Fuel Lab in mind... but are there other options?
I also plan to get a fuel pressure gauge in the cab so I can see it at all times instead of the contraption I have now that I duct tape to the windshield when I want to test it .
So, 2 questions... which pump/filter configuration should I go with... and why. And which regulator should I go with, and why.
Last question... trying to find out what these injectors flow in GPH from Swamps, and then I was going to see if dual stockers were even up to the challenge. Does anyone have some flow data for the stockers and maybe a few aftermarket pumps like the walbro or fuel lab etc...?
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #2 of 10 (permalink) Old 02-10-2009, 04:20 PM
fbilly420's Avatar
Re: DIY Fuel System
I have future plans that go like this.
-10 pick up and -10 line to water seperator
-10 line to fuel labs pump and -8 from pump to 2 micron filter and -8 from 2 mic filter to ITP bowl delete block. All with AN fittings.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #3 of 10 (permalink) Old 02-10-2009, 04:40 PM
HP Junky
Re: DIY Fuel System
My set-up is still holding up great, supported close to 600hp now. Never seen my fuel pressure gauge fluctuate.
5/8" pick-up to prefilter. 3/8" split to each stock pump. 3/8" lines back into post filter. 3/8" to ITP bowl delete. 3/8" on the return to tank.
RockinJW is offline
post #4 of 10 (permalink) Old 02-10-2009, 04:55 PM
cota's Avatar
Re: DIY Fuel System
What are you guys using for a post pump filter setup?
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
post #5 of 10 (permalink) Old 02-10-2009, 05:04 PM
HP Junky
Re: DIY Fuel System
RockinJW is offline
post #6 of 10 (permalink) Old 02-10-2009, 05:14 PM
10.61 @ 128 MPH
Powersmoker's Avatar
Send a message via AIM to Powersmoker
Re: DIY Fuel System
I have ITP 5/8 pickup, Dahl150 ( Fuel water seperator), A1000 pump, Itp's pump mount kit.
I am running all pushloc hose until the engine bay......then its all stainless braided.
-10 (5/8) from the tank to the pump, -8 out of the pump to a fuel splitter ( Y ) located on the engine. -6 from the splitter to the ports on the head.
My fuel pressure drops 3 psi at wot.
2000 F-250 Regular Cab
1069 RWHP 1768 Torque
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Murff Racing Twisted Diesel
Empire Diesel DieselSite
Swamps Diesel
Powersmoker is offline
post #7 of 10 (permalink) Old 02-10-2009, 10:12 PM
Banned
Re: DIY Fuel System
My pump is configured at ~50 to 60gph. I do not drop fuel pressure.
And fwiw... you're injectors are 300cc per 1000 shots. Shouldn't take you too long to figure volume flow @ any rpm of your choice. Their injection rate should not encroach on their ability to fully empty within a reasonable rpm limit.
Charles is offline
post #8 of 10 (permalink) Old 02-11-2009, 04:36 AM
What else?
smokyred's Avatar
Re: DIY Fuel System
Powersmoker, what kind of splitter are you running? Just something from Summit?
Dave
smokyred is offline
post #9 of 10 (permalink) Old 02-11-2009, 06:17 AM
DarkShadowDiesel's Avatar
Re: DIY Fuel System
Why not a sump?
2002 F250
DarkShadowDiesel is offline
post #10 of 10 (permalink) Old 02-11-2009, 07:31 AM
10.61 @ 128 MPH
Re: DIY Fuel System
Dave
correct. Just your normal jegs splitter, -8 in and -6 out
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Swamps Diesel
