obs motor into super duty - PowerStrokeNation : Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 38 (permalink) Old 08-06-2013, 02:26 AM Thread Starter
7.3
7.3's Avatar
ive been toying with the idea of a mild build for a month or so...even though i told myself i didnt wanna do anything to the truck when i bought it.. besides the point though lol. i got pmrs and a friend of a friend just rolled his 95 obs with 190k on it. said he would sell me the motor besides the turbo and injectors for 450 bucks if i take out myself. is that a good enough deal? i have no idea to be honest... so i been considering buying that and building as i can offord things. would that obs motor hook up just like the one i got? all the wiring and what ever else? i got a rough idea on what id like to do with the motor, but will probably change. i just need some pointers on obs motor in super duty, and if the price is right on that motor.
7.3 is offline
post #2 of 38 (permalink) Old 08-06-2013, 02:32 AM
Psd715's Avatar
Re: obs motor into super duty
That's a good price. Unless something really bad came from a compression test.
Only thing you'd really need to change would be the valve cover gaskets and uvch. And personally I'd just use the ones right off your current motor when the time came.
And pull the fuel pump and plug the hole.
'96 F-250 SCLB 4x4 Auto
3.5" dp 4" duals
Stealth dual hpop
Annd BIs on stock tuning.
Will
Psd715 is offline
post #3 of 38 (permalink) Old 08-06-2013, 02:39 AM
hunter scar's Avatar
I personally think that's a good deal I would buy it. Its a direct fit. Im pretty sure the only differences between obs and sd are the turbo, hpop ,injectors, the flywheel if you have a manual trans and the fuel pump. You can use the pcm in your sd just have it tuned for single shots.
1997 f250 ex cab short bed 4x4, 5 speed, tymar intake, 3inch mbrp downpipe to 5inch straight pipe, 2inch rough country front add a leafs. more to come. Totaled
2002 f250 ex cab short bed 4x4, 6 speed, tymar intake, 4inch downpipe to 5inch strightpipe, leveling kit ,issapro ev2 boost and pyro, PHP Hydra
hunter scar is offline
post #4 of 38 (permalink) Old 08-06-2013, 02:41 AM
Psd715's Avatar
He's not getting the injectors or turbo, and if he's doing a build, some form of hpop should be in there anyhow, though he could use the SD one anyhow. I'd def say go for it.
3.5" dp 4" duals
Stealth dual hpop
Will
Psd715 is offline
post #5 of 38 (permalink) Old 08-06-2013, 02:43 AM Thread Starter
7.3
7.3's Avatar
well building it id get rid of all that stuff anyways. and yeah it was mated to a zf5 and i got an auto so could i use my flywheel and have it resurfaced?
7.3 is offline
post #6 of 38 (permalink) Old 08-06-2013, 02:47 AM
Psd715's Avatar
Yep.
3.5" dp 4" duals
Stealth dual hpop
Will
Psd715 is offline
post #7 of 38 (permalink) Old 08-06-2013, 03:17 AM
Are front covers any different?
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #8 of 38 (permalink) Old 08-06-2013, 03:22 AM
Psd715's Avatar
I believe the differences are insignificant. But it'd def be worth double checking before one goes back in.
3.5" dp 4" duals
Stealth dual hpop
Will
Psd715 is offline
post #9 of 38 (permalink) Old 08-06-2013, 03:45 AM Thread Starter
7.3
7.3's Avatar
if they are they could be swapped over im sure?
7.3 is offline
post #10 of 38 (permalink) Old 08-06-2013, 03:55 AM
Psd715's Avatar
Definitely.
3.5" dp 4" duals
Stealth dual hpop
Will
Psd715 is offline
Closed Thread
