injector swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-22-2007, 02:20 AM Thread Starter
sled hauler's Avatar
injector swap
I'm installing injectors on my 97. ran into trouble removing the #7 injector, hits the a/c housing. anyone have the scoop on getting it out?
sled hauler is offline
post #2 of 7 (permalink) Old 10-22-2007, 02:46 AM
Don't EFN worry about it
Aljay's Avatar
Re: injector swap
Remove the insulation take out 2 screws 8mm one top one bottom. Move vacuum box out of the way and party on.
Tuned by T Wildman
Aljay is offline
post #3 of 7 (permalink) Old 10-22-2007, 03:08 AM Thread Starter
Re: injector swap
sounds like a plan, I'll get on it in the AM.
post #4 of 7 (permalink) Old 10-22-2007, 04:38 AM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
Re: injector swap
ya i am surprised you got the valve cover off w/o doin that it will make that much easier too
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #5 of 7 (permalink) Old 10-22-2007, 02:18 PM
racehauler's Avatar
Re: injector swap
I did the same thing when I put my injectors in. Getting the valvecover bolts out with that thing on there is a major PITA.
A little word of wisdom, set the valvecover back on while you are taking the inulation and vacuum box off. That will keep a bunch of dirt and crap from flying all over the exposed area.
And yes I do know this from expierence. You don't know how angry I was at myself for not thinking that one through before I ripped the insulation off there.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #6 of 7 (permalink) Old 10-22-2007, 11:14 PM Thread Starter
Re: injector swap
Well got it done. Had to buy new injector harness and valve cover gasket. Only mod done so far, can tell diff already!!! Thanks for the input
post #7 of 7 (permalink) Old 10-23-2007, 11:21 AM
Re: injector swap
Is there ageneral rule of thumb as to when injectors wear out,or does it depend on how well you did the required maintenance? My truck has 301000 miles on stock injectors. The truck runs much better now with new lift pump & a FASS system installed as my old lift pump died over the weekend.
cantrellc123 is offline
