Truck Falls on face - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 02-07-2009, 07:38 PM Thread Starter
psychoSOCIAL!!
helvis's Avatar
Truck Falls on face
when i spool up and launch in 4wd some times in first gear almost at the end of it when my rpms r maxed out just before it shifts my truck will just fall on its face, like down to an idle, then its fine again, and it only does it once in awhile not all the time, any ideas or has anyone experienced this?
02 7.3 psd, lots of useless mods.... (sold)
77 chevy c-10 2wd
87 fox body notch back 5.0
"The only difference between tattooed ppl and Untattooed ppl is, that tattooed ppl are way cooler....and can kick your ASS"
helvis is offline
post #2 of 21 (permalink) Old 02-07-2009, 07:41 PM
Deputydog's Avatar
Re: Truck Falls on face
Yep, mine was doing this too. It was a bad IPR in my case.
Deputydog is offline
post #3 of 21 (permalink) Old 02-07-2009, 07:46 PM Thread Starter
psychoSOCIAL!!
helvis's Avatar
how did you dtermine?
77 chevy c-10 2wd
helvis is offline
post #4 of 21 (permalink) Old 02-07-2009, 08:27 PM Thread Starter
psychoSOCIAL!!
helvis's Avatar
any other ideas guys, how to check this out or ideas?
77 chevy c-10 2wd
helvis is offline
post #5 of 21 (permalink) Old 02-07-2009, 08:55 PM
Deputydog's Avatar
With a scanner, watched ICP drop.
post #6 of 21 (permalink) Old 02-07-2009, 08:58 PM Thread Starter
psychoSOCIAL!!
helvis's Avatar
gotcha, what did yours drop too?
77 chevy c-10 2wd
helvis is offline
post #7 of 21 (permalink) Old 02-08-2009, 01:07 AM
When we were live tuning mine, it started doing the same thing. Turns out the we needed to shin the HPOP and it took care of the problem.
99 F350 CCLB
skav is offline
post #8 of 21 (permalink) Old 02-08-2009, 03:10 AM
Village Idiot
southmike's Avatar
you don't have big oil skav?
southmike is offline
post #9 of 21 (permalink) Old 02-08-2009, 03:22 AM
Sean had different issues. When demanding ICP above 3600, stock pumps blow-off.
Helvis, are you throwing any codes? Have you watched throttle voltage?
TerminatorEngineering is offline
post #10 of 21 (permalink) Old 02-08-2009, 04:09 PM
Sure do? We shimmed both pumps
99 F350 CCLB
skav is offline
