Water meth and oil change intervals - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 07-30-2013, 02:27 AM Thread Starter
Has anyone with running water meth on their trucks has any sort of oil analysis performed. I wanted to know a safe interval for oil changes running water meth. Will it be the same? The analysis will tell the real truth.
2002 F350 DRW, 38r Turbo, Terminator T500, REG return fuel system, CTS Evo Custom tuned by Bill at Powerhungry Performance, bts converter, S&B intake, Snows Stage 3 Water/Meth. Mcculloch hids 6k.
toypuller is offline
post #2 of 7 (permalink) Old 07-30-2013, 02:43 AM
01 SmokeChoke's Avatar
Re: Water meth and oil change intervals
I change every 3k on my odo. Its a bit off due to my tires but the oil seems fine when I dump it. No analysis performed I'd also like to hear from someone who did heres a bump.
IH Crate Engine,Cold Air,4" MBRP,6.5" lift,37" toyos,mx6 resis,Water meth,Stage 1s,Turbo Master,38R,6.0 CAC,6.0 trans cooler,FRx, Intank Mods,pre pump filter,AIH&EBPV deletes,Zoodad,456 yukon gears,Ladder bars,built trans,Aeroforce interceptor,quad pillar,PHP HYDRA,IH up pipes,Forged Rods
01 SmokeChoke is offline
post #3 of 7 (permalink) Old 07-30-2013, 12:32 PM
Sub'ed
94.5' XL F-350 cab chassis. Reg cab. Eby flatbed. 6637 intake, Tymar 3-4 dp, dual s.s. 6inch stacks, gauges (boost, pyro), cheap wad fpr mod w/ gauge, T-500, Rosewood stage II's 160cc/80%, dual superduty E-pumps, 6.0L intercooler, 3" plenums, 1.0 A/R housing, PHP 6 pos chip and user installed A/C, Gen II whicked wheel.
393 HP, 708TQ
King7765 is offline
post #4 of 7 (permalink) Old 07-30-2013, 08:26 PM Thread Starter
I consulted with Blackstones and ANA Labertories today. Both said they have seen NO reason to modify engine oil change intervals, due to running water meth. One guy said the wear material in the oil go up a little bit but nothing to really worry about. Change the engine oil like you normally would. This is great news.
post #5 of 7 (permalink) Old 07-31-2013, 02:30 AM
Thats kinda what I figured. Unless your running an obscene amount of water/meth I dont see why it would be a issue. I still do every 3k on my odo mobil delvac. Im running a 300 psi coolingmist pump with a single 750 cfm nozzle.
post #6 of 7 (permalink) Old 07-31-2013, 03:10 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Would not worry one bit about it.
Joe
CSIPSD is offline
post #7 of 7 (permalink) Old 08-01-2013, 03:09 AM
^ awesome. This is a guy who doesnt bull$hit.
Closed Thread
