upgrade help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 07-29-2013, 10:10 PM Thread Starter
hotrodhoward's Avatar
upgrade help!
Wanting to do some upgrades to my truck. Been doing some research and this is the pays list I have come up with. Let me know if there is anything I will need to make all these parts work good. Thanks in advance.
38r blank pedestal and bellowed up pipes
Adrenaline hpop
1944 south bend clutch
Fuel pump
238cc hybrids.
2000 f250 EX SB 4x4 zf6 speed w/ south Bend 3250 dd, riff raff OCR, riff raff frc, riff raff oil crossover, PHP 6 position chip 6637 air filter, glow shift 3 in 1 gauge, 4" down pipe with 5" exhaust.
hotrodhoward is offline
post #2 of 29 (permalink) Old 07-29-2013, 10:26 PM
the stryker god
Re: upgrade help!
head studs, valve springs. if you're gonna spend the money on a 38r with bellowed up pipes ect you might has well step up to a t4 or t4i with a s366 or somethin like a modded h2e or hx50. you'll also need a regulated return, but if your oem hpop is strong you might be able to retain it
bruce51d is offline
post #3 of 29 (permalink) Old 07-29-2013, 10:35 PM Thread Starter
Re: upgrade help!
The only problem I see with the t4 mounts and turbo is cost. Not looking to achieve more that like 400-450 rwhp. Are studs and springs really required?
post #4 of 29 (permalink) Old 07-29-2013, 10:42 PM
the stryker god
Re: upgrade help!
no, they are never required, but they are nice for peace of mind. hell if you only want that power level you don't even need 238's, you could do 175's
bruce51d is offline
post #5 of 29 (permalink) Old 07-30-2013, 12:32 AM
Tim @ P.I.S.'s Avatar
Re: upgrade help!
For 400-450 go with 200/80's. no need for a hpop and the 38r will work perfect with it. We have done this combo dozens of times with great results.
Tim @ P.I.S. is offline
post #6 of 29 (permalink) Old 07-30-2013, 01:00 AM
the stryker god
Re: upgrade help!
yep that would work too, holler at tim, he makes a very nice injector
bruce51d is offline
post #7 of 29 (permalink) Old 07-30-2013, 01:12 AM
Rustbucket
data_engine's Avatar
Re: upgrade help!
Start at the tank! Don't feed those injectors fuel froth! You'll need to upgrade the fuel lines from the tank to the pump. Compared to your mentioned mods, the cost is practically free!
"Lets Eat Grandma!"
"Lets Eat, Grandma!"
Commas Save Lives!
1999.5 F350 7.3 PSD Auto, 8" Lift, Nitto 38s, Hutch" Mod, AIH Delete, Fuel Pressure, Pyro & Boost Gauges, 4" Magnaflow turbo down, Riffraff Intake, Grand Rock 5" single stack, TS 6 Pos Chip
data_engine is offline
post #8 of 29 (permalink) Old 07-30-2013, 01:31 AM Thread Starter
Re: upgrade help!
Who is Tim? And when I do injectors I was thinking of the irate diesel pre pump filter and maybe a sump. Kinda cheap to do those. Is that what you mean?
post #9 of 29 (permalink) Old 07-30-2013, 01:35 AM
the stryker god
Re: upgrade help!
tim at performance injection systems. he means the intank mods hutch and harpoon. mainly the hutch mod. search it on here or on google. fuel systems can add up quick, also there is an s366 kit in the classifieds for 1400 to your door, thats like a sore dick, you can't beat it
bruce51d is offline
post #10 of 29 (permalink) Old 07-30-2013, 05:42 AM Thread Starter
Re: upgrade help!
What fuel pump would you guys recommend? And you say I don't need an hpop but my truck has 235000+. Which would be better for me adrenaline or the t500?
