couple random ?'s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 02-06-2009, 01:49 AM Thread Starter
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
couple random ?'s
what ever happened to the 20* hpop?
where do you get a melling lpop?
what psi should you thing about fire rings?
thanks
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #2 of 24 (permalink) Old 02-06-2009, 02:36 AM
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
Re: couple random ?'s
thanks
Melling LPOP @ your local O'Riley's store. The other questions im sorry i can't help you!
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
post #3 of 24 (permalink) Old 02-06-2009, 04:16 AM
What else?
smokyred's Avatar
There are still some 20* pumps running around, pretty sure Dieselfever still has one on one of his trucks, and I'm pretty sure Unlimited has one in a Gen3 setup. From what I was told, the cost is near the same as a Gen3, but obviously the Gen3 can flow much more oil, so there is no real need for the 20*
Dave
smokyred is offline
post #4 of 24 (permalink) Old 02-06-2009, 04:18 AM
PSDfan99's Avatar
Who even made a 20*?
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #5 of 24 (permalink) Old 02-06-2009, 05:35 AM
What else?
smokyred's Avatar
Swamps made them back a few years ago, before there was big oil. I'm not sure if they would still have one made for you if you wanted one, but I'm sure it couldn't hurt to ask them.
Dave
smokyred is offline
post #6 of 24 (permalink) Old 02-07-2009, 07:57 PM Thread Starter
Crazy Talk
sice two are answered got another one lol. at what point is a billet intermediate and output shafts needed in an e4od
post #7 of 24 (permalink) Old 02-08-2009, 02:50 AM
HRT Performance
HotRodTractor's Avatar
thanks
Fire rings..... juries still out but I would be cautious about adding them to a PSD. There are several guys that have had some issues with them, and a few guys that seem to make them hold. I have some new information and some improvements to the fire ring setup that I have been researching to help me with my issues. All fire ring setups are not created equal.
Jason
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #8 of 24 (permalink) Old 02-08-2009, 03:12 PM Thread Starter
Crazy Talk
got ya. can these heads be o ringed like a cummins, where you still use the stock gasket.
post #9 of 24 (permalink) Old 02-08-2009, 03:35 PM
Banned
I slipped up and ran over 90lbs of boost the other day. Worst was 93lbs. I backed the boost back down to a reasonable 70 or so when I noticed it and all is well. I ran WOT about 4 or 5 times over 85lbs before I realized where the boost was.
Blew the bottom port line off the second stage wastegate.
Cometics still rockin out.
Charles is offline
post #10 of 24 (permalink) Old 02-10-2009, 01:08 AM Thread Starter
Crazy Talk
so any thoughts on billet intermediate and outputs? moremph?
