Converter randomly not locking? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 02-06-2009, 01:00 AM Thread Starter
matthewd11's Avatar
Well today i was doing a quick WOT pull (1st-3rd) and then immediately got on the highway. The converter did not lock for some reason. It is a new PI stallion with a fresh (built) transmission. It eventually locked up a few miles down the road. Fluid temp was around 105*F when this occured. It acted as though the fluid was not yet warm enough for it to lock up. FWIW it was about 10*F or colder outside when this happened. This was also the first and only time it has done this.
Afterward driving around town it seemed to lock up with the normal firmness. This whole setup has about 500 miles on it.
Fluke or something i should be concerned about?
matthewd11 is offline
post #2 of 14 (permalink) Old 02-06-2009, 01:07 AM
PSN Pretender
907DAVE's Avatar
Re: Converter randomly not locking?
Mine does that alot, but the temps are normally -20 to -40. Works fine when both engine and tranny are warmed up.
907DAVE is offline
post #3 of 14 (permalink) Old 02-06-2009, 01:29 AM Thread Starter
matthewd11's Avatar
my converter usually locks when the fluid temp 50* though. That is the only descrepancy from usual operation. The fluid temp only increased a few degrees until it locked this particular time.
post #4 of 14 (permalink) Old 02-06-2009, 01:31 AM
greenbeast's Avatar
Put in a switch to lock it manually and see what happens.
greenbeast is offline
post #5 of 14 (permalink) Old 02-06-2009, 01:35 AM
Was the od light flashing?
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
post #6 of 14 (permalink) Old 02-06-2009, 01:40 AM Thread Starter
matthewd11's Avatar
No.
I'll consider the switch, but i'd rather not, especially in this cold.
post #7 of 14 (permalink) Old 02-06-2009, 01:47 AM
PSDfan99's Avatar
Scott will tell you that the TC lock switch will do more harm than good. That's what he told me when he built my tranny, haven't used it since I left his shop.
I'd call him and see what he has to say.
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #8 of 14 (permalink) Old 02-06-2009, 01:48 AM
I think if the pcm was telling the tc to lock and it wouldn't, you would get the light on the shifter flashing.
rpm-inc is offline
post #9 of 14 (permalink) Old 02-06-2009, 01:49 AM Thread Starter
matthewd11's Avatar
the converter is not from him though, its from David at DI.
I'm not sure what he can do, since its not really a transmission issue per say. The trans itself is doing great. This is the only hiccup the whole setup has had so far.
I'll check codes again on my scangauge, but i did not notice any O/D light flashing. If it did flash, there should be something in history or current i would think.
Also, why would it lock up fine afterward and only this once not lock up? If it was a real problem i would think it would do it all the time..
post #10 of 14 (permalink) Old 02-06-2009, 05:06 PM
IDP
Some trucks wont go to lock up until the engine and trans warm up and hit a certain temp.
IDP is offline
