Building a stronger block - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 02-05-2009, 11:59 PM Thread Starter
BIG"E"'s Avatar
At what point do you need to start lookin at a partial filled block or girddle? Are both of these streetable for a d/d?
In the market for a new powerstroke!
BIG"E" is offline
post #2 of 23 (permalink) Old 02-06-2009, 02:19 AM
fueled by Colecovision
golfer's Avatar
Garage
Re: Building a stronger block
I wouldn't yank a perfectly good (running) engine out unless you have big plans...
with that said...I wouldn't build a 500+hp engine without filling the block...unless it was going to STAY a 500hp engine.
We have a number of customers DD'ing (towing, working, driving) these trucks on filled blocks (up to 1.75" below deck surface) with no problems related to cooling.
golfer is offline
post #3 of 23 (permalink) Old 02-06-2009, 02:27 AM
Turbo99's Avatar
Dave how is the oil temps on a block filled that high? I know when I had a 460 bored and stroked to 540 back in the day it was filled about half way and the water temps were good but the oil temps would get alittle warm.
_____________________________________________
Jeremy
08'F250 CCSB 4x4 ALL White except whats Black!!
10' Camaro 2SS LS3 All White except whats Black!! Supercharged 682 RWHP 10.80 @ 131mph
Turbo99 is offline
post #4 of 23 (permalink) Old 02-06-2009, 02:43 AM
golfer's Avatar
Garage
The first two we filled (dedicated pullers) were maxed out with data logging junk...juuuussstt in case anything got out of control...
nothing, nada...other than one clogged oil cooler (which did raise oil temps) ..but I think that was more from not cleaning the loose HardBlok particles out from the filled areas as well as it should have been...
but it wasn't for anyone really important...
just Charles.
We might recommend a coolant filter on the filled blocks...seen some small particles (like dust) in the coolant res...
but the alternative to not filling these things...is a little LESS than forgiving,
golfer is offline
post #5 of 23 (permalink) Old 02-06-2009, 03:06 AM Thread Starter
BIG"E"'s Avatar
Well sence I have pmrs I am looking for a builder engine to tear down and build. I am shooting fo right around 500, but if I know me the building never ends. So if I am going to start playing the game I might as well do it right from the get go. So I should fill the block. What about the girdle?
BIG"E" is offline
post #6 of 23 (permalink) Old 02-06-2009, 03:19 AM
golfer's Avatar
Garage
A proper girdle is a good investment...
golfer is offline
post #7 of 23 (permalink) Old 02-06-2009, 03:23 AM
Powerstroke Racer's Avatar
What is a proper girdle?
Powerstroke Racer is online now
post #8 of 23 (permalink) Old 02-06-2009, 03:38 AM
golfer's Avatar
Garage
...something that actually prevents the block & crank from flexing and keeps the main caps stationary.
not something that acts as a spacer for the main stud nuts.
golfer is offline
post #9 of 23 (permalink) Old 02-06-2009, 03:46 AM
sooo who makes a proper girdle?
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #10 of 23 (permalink) Old 02-06-2009, 03:50 AM
OverFuelingForYourPlesure
pontiacross's Avatar
I think I remember geoff thomas talking about machining out around the bolt holes of the caps and the block a little bit and driveing a hollow bushing in there to keep the caps from walking. Is that something that has been done or just something he was dreaming up?
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
