Anyone tried insulating their valve covers for less clatter? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 39 (permalink) Old 02-05-2009, 05:18 PM Thread Starter
Junior Mint
I'll be under the hood this weekend (time to reinstall the BDs, check stud tq, fix front cover leak, and ceramic coat the turbine housing) and I was considering ways to quiet the truck down a bit more.
Anyone considered maybe coating the valve covers w/ bedliner or something else to reduce that valve train and injector clatter?
Thanks.
I'm officially...Stroke-less.
Suns_PSD is offline
post #2 of 39 (permalink) Old 02-05-2009, 05:19 PM
Re: Anyone tried insulating their valve covers for less clatter?
put some dynomat on the inside of them
PMRCM#1
slowleak is offline
post #3 of 39 (permalink) Old 02-05-2009, 05:22 PM
theSLEEPER's Avatar
Does that really work?
theSLEEPER is offline
post #4 of 39 (permalink) Old 02-05-2009, 05:34 PM Thread Starter
Junior Mint
Inside???
Are you crazy?
Suns_PSD is offline
post #5 of 39 (permalink) Old 02-05-2009, 05:41 PM
Village Idiot
LRTMatt's Avatar
I can't see Dynomat lasting very long in all there with all that heat and oil! I'm sure it would help if applied to the outside of the covers. In the end I think you will find that much of the engine noise resonates from all over and a reduction in noise from the valve covers won't make much difference.
LRTMatt is offline
post #6 of 39 (permalink) Old 02-05-2009, 05:57 PM
Hater Club
Dirk's Avatar
rhino liner on the outside.
Porch Monkey. It's cool, I'm taking it back.
Dirk is offline
post #7 of 39 (permalink) Old 02-05-2009, 06:43 PM
Your best bet would be tuning to quiet the engine down. thats my .02
ohiopsdfordman is offline
post #8 of 39 (permalink) Old 02-05-2009, 07:23 PM
Layson's Avatar
At idle I bet it could be slightly quieter...
Layson is offline
post #9 of 39 (permalink) Old 02-05-2009, 07:41 PM
Keyboard Thug
Big Bore's Avatar
Spray the inside of the covers with foam sealer. Put saran wrap over the rockers and injectors. Place VC's in place and allow to harden. Remove, take off plastic, reinstall.
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
Big Bore is offline
post #10 of 39 (permalink) Old 02-05-2009, 07:49 PM
Hater Club
Dirk's Avatar
Sounds interesting, I don't trust the order in which you listed them.
Dirk is offline
