sick of shopping - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 07-27-2013, 08:48 AM Thread Starter
User Error
buck90's Avatar
sick of shopping
I have a lift from Xtreme Off Road in Georgia. Idk if they sell crappy lift kits or the owner flubbed the install, but the lift kit was sold as a 6" all around lift. However, the front leafs are 6" but the back leafs are factory w/helper spring and 2 blocks stacked on top each other. Definitely bad juju. Figured screw it, I'll get a REAL lift where I get 4 lift springs vs 2 and an assortment of blocks. Problem is, Im looking to go 8 inches and nobody sells the kits other than 4 wheel parts,(at least not anyone else that I could find) and I know good n well leaf lift springs dont cost near $390 apiece for 8" lift. Anyone got any leads to a company that sells an 8 inch lift leaf kit with shocks for less than $1700? Maybe know someone that has a used kit in good condition willing to strike a deal? Anything 6" or HIGHER. I know for a fact with that price, 50% of it is the 4 wheel parts logo.
I work with people entrusted to maintain and repair $110 million airplanes, but can't change a car battery.
2001 F250, Floyd's Stage 3 trans, GTP38R, aFe Stage 2 intake, TS Performance 6 position, 5" Diamond Eye straight turbo-back, 6" Pro Comp lift, 36" Nitto Terra Grapplers
buck90 is offline
post #2 of 3 (permalink) Old 07-27-2013, 11:43 AM
jtgf250's Avatar
Re: sick of shopping
Actually when you go over a 4 inch lift and want 4 new springs( not adding a stack0 in the rear, kits get pretty pricey. That sounds like average to me for that kit. the add a block in the rear is the cheaper route though. They're are lots of vendors on here that can hook you up though.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #3 of 3 (permalink) Old 07-27-2013, 03:06 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Just get a single taller block... Never stack blocks.
Joe
CSIPSD is offline
Closed Thread
