Gauge Installation - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 02-04-2009, 10:52 PM Thread Starter
The Ontaribertan.
Sluther's Avatar
Thumbs up Gauge Installation
I just my first truck, and am starting to throw some mods on her. Its got an intake and straight pipe and I'm looking at a chip now, so I wanna make sure I have gauges set up first. My question is where and how are the best places to install the sensors for the pyro and trans temp gauges? Is the downpipe best for the pyro? Just drill and put it in? I know its an amateur question but any advice helps. Thanks.
SOLD -- 2000 F250 7.3 RegCab 4x4
2001 F250 SCSB 4x4 Lariat 120k -- 2.5" Levelled, Duelers on 20in Fuel Octanes, K&N Intake, MBRP 4", DP Tunes, AutoMeter Ultra-Lites.
1971 Chevelle 454 SS Clone -- Father/Son restoration
Sluther is offline
post #2 of 18 (permalink) Old 02-04-2009, 10:54 PM
secondarychaos's Avatar
Re: Gauge Installation
NOT IN THE DP!
for the pyro, there's a nice flat spot on the driver's side manifold. you want your readings to be pre-turbo. and you have to tap the hole too, so make sure you're using the right size bit for the tap, for the probe. clear as mud?
on the driver's side of the transmission there's a plug, about two thirds of the way forward... there's a pic on the intraweb, lemme see if I can find it.
boost-just tee into the MAP line.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #3 of 18 (permalink) Old 02-04-2009, 11:00 PM
Binder man's Avatar
I prefer the Y pipe for the boost. It's pretty thin metal but if you put a overboost annhilator on the truck you won't have to worry about false readings.
Early 99, regular cab, Six Speed, Wildman Tuned, Red wastegate line MIA, muffler MIA, Isspro EGT/Boost, DIY Tymar, EBPV Switch, a slipping South Bend, 2.5" leveling kit, 35x12.5 BFG All-Terrains, 16.5" American Racing wheels SOLD
04, red regular cab, six speed, Edge SOLD
97, silver regular cab 300/200 s300
Binder man is offline
post #4 of 18 (permalink) Old 02-04-2009, 11:40 PM
Then you can remove the AIH at the same time. Improve air flow.
Muley is offline
post #5 of 18 (permalink) Old 02-05-2009, 01:40 AM
Freedom is not free
White Buffalo's Avatar
Here is a link to Diesel Manor's installation instructions with pictures. A great resource to review.....
http://dieselmanor.com/diy/PSD3-gauge/PSD73gauge-p1.htm
White Buffalo is offline
post #6 of 18 (permalink) Old 02-05-2009, 02:19 AM
DD Assisted
DieselRangerKid's Avatar
I welded a bung on my up-pipe and installed the pyro there.
2002 Ford F-250, 7.3, 6spd.
1984 Ford Ranger Diesel - Top Secret
2007 Mazda 6
1952 GMC w/ Ford powertrain, 390, Top Loader 4spd.
2006 Honda TRX450r - Some stuff
2003 Suzuki Eiger
8 John Deere's from 1953 to 1960
Give'r the Onions
DieselRangerKid is offline
post #7 of 18 (permalink) Old 02-05-2009, 02:56 AM
psdmike's Avatar
He said Bung
1997 F350 Crew Cab, 7.3, 4x4, 5SP Short Shift kit, 5" RSK SD V Code springs, DIY Intake, 5" Exhaust with 30" FTE Resinator, intercooled, TS chip.
psdmike is offline
post #8 of 18 (permalink) Old 02-05-2009, 02:56 AM
Smarty Power!
John_DeereGreen's Avatar
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
My pyro probe is clamped on my driver's side manifold. Seems to be fine to me...
I wouldn't want one in the down pipe. The charger is too much of a heat sink.
Jarrett Matthew
04.5 QCSB auto common rail
Smarty TnT; ISSPRO PERFORMAX
Suncoast full billet
John_DeereGreen is offline
post #9 of 18 (permalink) Old 02-05-2009, 03:17 AM
DD Assisted
Bung makes me laugh too (I need some bungin', did you get some bungin?)
2007 Mazda 6
2003 Suzuki Eiger
Give'r the Onions
post #10 of 18 (permalink) Old 02-05-2009, 05:03 AM
<-- GO BRONCOS
dblamp's Avatar
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
