bully dog help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-25-2013, 11:00 PM Thread Starter
s10mike's Avatar
bully dog help
I have an 03 f250 with a 7.3. it has a bully dog 6 position tuner that seems to be stuck in high idle mode. no matter where I put the switch it still idles way high. anyone know what might be the matter with it? thanks
s10mike is offline
post #2 of 10 (permalink) Old 07-25-2013, 11:08 PM
jtgf250's Avatar
Re: bully dog help
May be the switch itself. Trash the whole thing and get a better style chip from a vendor on here. Would be much better for the truck
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #3 of 10 (permalink) Old 07-25-2013, 11:32 PM
mtray's Avatar
Re: bully dog help
agreed...pull it, get rid of it and get some custom tunes, from NLTD, gearhead, swamps,PHP, ect.
2000 Ford F250 7.3 4x4. MODS: Beans Tunes, Jegs 4" exhaust, S&B intake, boost fooler, USA poted housing, RR billet wheel for ported housing, HFO, glowshifts 3-in-1 gauge pyro, boost, trans. AIH delete, bellowed uppipes, Sinister Diesel coolant filter.
mtray is offline
post #4 of 10 (permalink) Old 07-25-2013, 11:38 PM
Raul@stealth-automotive's Avatar
Send a message via AIM to Raul@stealth-automotive
Re: bully dog help
just pull it out..... that will take care of the issue.. if you dont want to do that it sounds like you need a new switch...
-Raul
post #5 of 10 (permalink) Old 07-26-2013, 12:19 AM Thread Starter
s10mike's Avatar
Re: bully dog help
thanks guys. I got it to work by taking out the switch and spraying a little contact cleaner in there. now I am wondering what is the matter with the bully dog setup? it seems to run pretty good, other than that switch sticking, I never had a problem with it.
s10mike is offline
post #6 of 10 (permalink) Old 07-26-2013, 12:25 AM
Re: bully dog help
their isnt anything "wrong" with it... its just that their are far better tunes out their.... but it may not be worth upgrading to you if yours is already running fine.... are you running gauges?
post #7 of 10 (permalink) Old 07-26-2013, 01:12 AM Thread Starter
s10mike's Avatar
Re: bully dog help
stock gauges. it does have a trans. temp. guage; stock
s10mike is offline
post #8 of 10 (permalink) Old 07-26-2013, 01:23 AM
Re: bully dog help
those are usless.... they are dummy lights at best...
i would recommend getting some aftermarket gauges... boost, pyro and trans temp...
post #9 of 10 (permalink) Old 07-26-2013, 01:27 AM
the stryker god
Re: bully dog help
i think no limit can put tunes on that chip. it will be like a night an day difference
bruce51d is offline
post #10 of 10 (permalink) Old 07-26-2013, 10:00 AM
FL-DIESEL's Avatar
Re: bully dog help
bullydog is hard on trannys and known for high egts... i used to have a superchip when i first got the truck, switched to some of jodys tunes at dp and it was night and day difference... id recommend doing yourself a favor and hook up with dp, php, or gearheads and get a setup ordered, and throw in an egt,boost,and trans temp gauge.. best 700$ ive spent on the truck
2002 7.3 stabbin waggon ... 4in turbo back, cold air, autometer pillar, dp-tuned...more to come, feel free to make donations
FL-DIESEL is offline
