HPX?? for high HP guys - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 02-04-2009, 12:50 PM Thread Starter
Just A Squirrel
dstruble's Avatar
well i finally fixed my oil leak!!! HPX line was leakin 60 k on it so im not too upset, any way should i replace it with a ss hard line or do away with it totally??? Is it necessary to run higher HP or jusy a drivability piece?? thanx for opinions and info!!
Darrin Struble
2003 F-350XLT Sport SC/SB
7.3L Live tuned by Jody ,ITP reg return/intank prepump mods, MBRP S.S. 4" ,afe stage1,foil delete,WW, Dieselsite coolant/trans filters,turbomaster wastegate controller,FTVB,Bandwagon Badges
1956 f100 Heidts Suspension all around
dstruble is offline
post #2 of 20 (permalink) Old 02-04-2009, 12:54 PM
Banned
Re: HPX?? for high HP guys
Who knows.
But fwiw, my braided one has been on there for at least a couple hundred thousand miles now.
Charles is offline
post #3 of 20 (permalink) Old 02-04-2009, 12:58 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Nicks DI SS line blew the other day... Only thing that kept him from walking home was I was in the area with my plugs and 2 gallons of oil.
My ITP version leaks from time to time, just needs a small tweak to stop it, but I never saw a bit of differance from installing it or removing it. Only thing I noticed was one more thing to pull when changing turbos.
Joe
CSIPSD is offline
post #4 of 20 (permalink) Old 02-04-2009, 12:59 PM Thread Starter
Just A Squirrel
dstruble's Avatar
thnx Charles rub it in!!!J/K whos are ya running???
Darrin Struble
dstruble is offline
post #5 of 20 (permalink) Old 02-04-2009, 01:00 PM
Banned
I thought the question was in reference to high hp applications?
Charles is offline
post #6 of 20 (permalink) Old 02-04-2009, 01:09 PM
CSIPSD's Avatar
Your right, I am only in the 450-500 range... low hp compared to you...
Joe
CSIPSD is offline
post #7 of 20 (permalink) Old 02-04-2009, 02:17 PM
CSIPSD's Avatar
Ya, and 460 with my junk TN-BB... Poor me, 460hp with a turbo you can't stand...
How many 7.3 guys on here have dyno sheets above 450 hp??? Bet less then 15...
I am sorry to say but "high hp 7.3" is above 400...
Joe
CSIPSD is offline
post #8 of 20 (permalink) Old 02-04-2009, 03:00 PM
theSLEEPER's Avatar
Dude... Chill out...
theSLEEPER is offline
post #9 of 20 (permalink) Old 02-04-2009, 03:48 PM
CSIPSD's Avatar
Ask yourself if I am worked up???
Joe
CSIPSD is offline
post #10 of 20 (permalink) Old 02-04-2009, 04:28 PM
Lovin the Tuna
RedSmokey's Avatar
how can he ask himself if YOUR worked up?
2001 F250
2000 F250
RedSmokey is offline
