What the heck is wrong with my truck! High.egts - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 60 (permalink) Old 07-24-2013, 03:48 AM Thread Starter
Sooo sick of having to keep my eyes pegged to the egt gauge and not being able to maintain speed with the traffic!. Recently switched to gear head tunes from dp because people were saying that was one of the causes. In the heavy tow setting towing my boat which is a 31 contender on a trip axle trailer. I'd guesstimate it at 10-12k. If I even try to run 70 down the turnpike here in Florida which is dead flat without going over 1200*. So I have to just sit at 60 with overdrive locked out at 1000*. No boost leaks, no evidence of soot from drive pressure leaks. What's the deal?
[color=gray]Sent from AutoGuide.com Free App[/color
2000 F250 ccsb 4x4. 218,000 miles, 38r 1.0 housing with turbo master, 238/80% FFD hybrids, BTS
riff raff FRx, Autometer C2 series gauges, DIY tymar, remote start, Hydra with GEARHEAD Tunes
lariat7.3 is offline
post #2 of 60 (permalink) Old 07-24-2013, 08:00 PM
Layson's Avatar
Re: What the heck is wrong with my truck! High.egts
Did you talk to Jody about your issues before you just start spending money switching tunes...
What kind of boost numbers are you seeing? Did you actually go though and make a boost leak detector and check the system?
You have that wastegate tightened all the way down?
Layson is offline
post #3 of 60 (permalink) Old 07-24-2013, 11:31 PM Thread Starter
Yes yes and yes. Double and triple checked. That's why I'm asking I can't figure it out.
post #4 of 60 (permalink) Old 07-24-2013, 11:33 PM Thread Starter
I'm all for other suggestions
post #5 of 60 (permalink) Old 07-24-2013, 11:38 PM
the stryker god
Is the gauge accurate?
bruce51d is offline
post #6 of 60 (permalink) Old 07-24-2013, 11:47 PM Thread Starter
Egts.1000 rpm 2300 boost 7# speed. 60mph locked out of overdrive
post #7 of 60 (permalink) Old 07-24-2013, 11:57 PM
theoldgirl1990's Avatar
My dad's superduty had the same problem. I looked under the hood and noticed that the c-clip for the wastegate rod had fallen off and the flapper was just sticking open. A result was a bleedoff of a lot of pressure resulting in high egt's. Take a look at the wastegate rod on the turbo and see if it is still connected.
1996 F-350 cclb, H2E, e-fuel, srp1.1, custom tuning, banks intercooler, 3 in plenums, swamps babies, ARP's, comp 910's, Isspro EV2's, rsk v/c codes, 5 inch exhaust, king ranch seats, SD 10.5 axle, swamps idm, 6.0 fan, international w/p, hydroboost, SD trans lines, 6.0 trans cooler,6.0 P.S. pump
theoldgirl1990 is offline
post #8 of 60 (permalink) Old 07-25-2013, 12:05 AM Thread Starter
Have a turbo master controller that has the waste gate shut
post #9 of 60 (permalink) Old 07-25-2013, 12:35 AM
Layson's Avatar
What kind of boost numbers are you seeing? When you are towing are you seeing a lot of smoke? What color is the smoke?
Layson is offline
post #10 of 60 (permalink) Old 07-25-2013, 12:36 AM
300,000 and counting's Avatar
Check to see how dirty the intercooler/ radiator/ everything up front is, it makes a big difference from clean to extremely dirty, also I'm sure you checked tho but how is your air filter
2001 7.3 PSD, Swamps 200/30 injectors, 38r turbo, HPx, FRx, bellowed up-pipes, non-ebpv ped, Gearhead tuned TS 6 pos chip, AFE big boost intake, 4" downpipe; 5" exhaust, BTS valve body, 31 row tranny cooler, autometer gauges, 05-07 front end, centurion rear bumper, 327,000 miles FOR SALE
2009 6.4 PSD, 71mm LP, studded, delete, H$S Mini Max
300,000 and counting is offline
