is there such thing as to much black smoke? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 28 (permalink) Old 07-24-2013, 12:07 AM Thread Starter
7.3_geek_124's Avatar
You can tell in my signature what I have done, I still have the stock pump. And for some reason I get crazy amounts of black smoke. Even when Im just driving down the road at a normal speed I get a light constant haze of smoke. Just doesn't seem like thats normal especially for my mods.. any ideas??
Late model 99 ext cab - Exterior: 05 front end, 08 mirrors, 08 tail gate, 10 inch skyjacker lift on full springs, 22x13.50 moto metal 962's wrapped in 37" Toto mt's.
Engine: swamps 160/100 sticks, turbonetics turbo with a 63/91 comp wheel, gauges, riffraff ocr, riffraff intercooler boots, ts 6 pos chip.
7.3_geek_124 is offline
post #2 of 28 (permalink) Old 07-24-2013, 12:24 AM
7.3psd1999's Avatar
Re: is there such thing as to much black smoke?
You could have a simple boost leak causing it or it might be normal with you tuning. My 7.3 used to haze at cruising speeds with d66 turbo and stock sticks.
2009 f250 lariat 6.4
Ats tranny
Innovative tuning
Afe intake
4" straight pipe
Leveled on 33x13.50
7.3psd1999 is offline
post #3 of 28 (permalink) Old 07-24-2013, 12:26 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
It is most likely in the tuning
Stock
PowerstrokeJunkie is offline
post #4 of 28 (permalink) Old 07-24-2013, 12:29 AM
jaybuller's Avatar
Doesn't sound normal. Could just be a matter of bad tuning, or a turbo that isn't lighting. Could be a bad injector dumping to much fuel. Like stated above could be a huge boost leak or a bad pre turbo exhaust leak in the uppipes or manifold. S many variables but I would get it taken. Care of. Nobody wants to drive around wasting diesel like that.
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #5 of 28 (permalink) Old 07-24-2013, 12:59 AM Thread Starter
Ok well where should I start? How do you check if it's a tune?
post #6 of 28 (permalink) Old 07-24-2013, 01:04 AM
Know your SIG says ts 6 position but who's custom tunes do you have on it?
Build or buy a boost leak checker and start there. Also check your up pipes for signs of leaking. Black soot.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #7 of 28 (permalink) Old 07-24-2013, 01:23 AM
the stryker god
63mm inducer turbo is pretty small for 160/100's imo. even a 38r that is a 66mm inducer has problems clearin up stage 2's. but tunin and boost or drive leaks are a good start
bruce51d is offline
post #8 of 28 (permalink) Old 07-24-2013, 01:23 AM Thread Starter
Well when I bought my swamps sticks I bought the chip from them and had them tune it for everything done with my truck.
post #9 of 28 (permalink) Old 07-24-2013, 01:25 AM Thread Starter
Should I go with a wicked wheel or something. Or a completely different turbo?
post #10 of 28 (permalink) Old 07-24-2013, 01:27 AM
the stryker god
i doubt you'll find a ww for that turbo, a tuner can make any injector smoke free but you won't make the power like you would if you had proper amounts of air
bruce51d is offline
