Irate plenums??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 07-22-2013, 02:11 AM Thread Starter
Irate plenums???
Mine were just installed and are leaking a lot on the bottom where the pipe is.
Anybody else have that problem or is there some trick to the install?
kickstand is offline
post #2 of 19 (permalink) Old 07-22-2013, 02:29 AM
the stryker god
Re: Irate plenums???
make sure you use the grey ford silicone and don't be afraid to lay it on
bruce51d is offline
post #3 of 19 (permalink) Old 07-22-2013, 03:08 AM Thread Starter
I had a shop do it and they used a grey rtv, don't know which one though.
I can feel a bead of rtv under there when I test it with air, it's blown out.
I don't know if they didn't let it dry long enough or they just missed the sealing surface when they put it on.
Would you just put them finger tight over night and then tighten them or would you tighten them up immediately after applying the rtv?
post #4 of 19 (permalink) Old 07-23-2013, 09:03 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Riffraff Diesel: Riffraff Diesel Billet Intake Manifold Plenums
Problem solved...
Joe
CSIPSD is offline
post #5 of 19 (permalink) Old 07-23-2013, 10:45 PM
Village Idiot
southmike's Avatar
Originally Posted by CSIPSD View Post
*Will not fit 94-Early 99 with stock turbo
boo... not that a e99 with a stock turbo needs them but wonder what the clearence issue is.
southmike is offline
post #6 of 19 (permalink) Old 07-24-2013, 12:16 AM Thread Starter
Hmm that looks alright, wonder if anybody has ever used these and if they actually work as advertised?
Also wonder if they will work with a 468?
post #7 of 19 (permalink) Old 07-24-2013, 01:40 AM
CSIPSD's Avatar
Yes... Lots of people have used them...
It will fit for sure with the 468, not sure about the race cover however.
Joe
CSIPSD is offline
post #8 of 19 (permalink) Old 07-25-2013, 03:31 AM
JHill's Avatar
yes they will work with the race cover . Jake runs that turbo/plenums on his personal truck 50#+ boost . short of a manufacturing issue, guessing the shop may have rushed it or didnt put enough on. idk
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #9 of 19 (permalink) Old 07-25-2013, 06:10 AM
maybe they didn't prep surfaces well.
try right stuff =D and dont be scared to lay it on, normally put it on and let it start to get tacky then tighten (usually not longer than 20 minutes)
our engine builder gets mad when we use it on stuff cause he practically needs dynamite to unseat it, lol
Darkhorse: E99 F-350 SD Dually, RWD, 4r100, 4inch, K&N intake, TS stock tunes, 05 conversion, Murdered, Irate mounted S468fmw, SRP 1.1, ARP, regulated return, water/meth
Fearmont: 79 Ford Fairmont, X275 drag radial car, BES 574ci A-headed Ford, ATD 2 speed Turbo 400, Menscer's, 9.5in Duco rearend, 1 stage nitrous. 4.60's @ 153mph
PlimptonJr is offline
post #10 of 19 (permalink) Old 07-25-2013, 08:30 AM
CSIPSD's Avatar
Jake runs Riff Raff's plenums?
He was asking about Riffraffs fiting with it...
Joe
CSIPSD is offline
