royal purple vs motorcraft - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 07-21-2013, 11:09 PM Thread Starter
User Error
buck90's Avatar
Its almost time for another oil change. So far I've used only rotella-T and motorcraft. Just on a whim I read up on royal purple. It says comparable with gas AND diesel engines. As with most theories, a product that does the job of 2 separate products usually isn't as good as the purpose built product. Is this the same here? Is the extra $5/gal for the dual purpose use? Or is it worth it to my diesel to pump out an extra $20 this oil change?
I work with people entrusted to maintain and repair $110 million airplanes, but can't change a car battery.
2001 F250, Floyd's Stage 3 trans, GTP38R, aFe Stage 2 intake, TS Performance 6 position, 5" Diamond Eye straight turbo-back, 6" Pro Comp lift, 36" Nitto Terra Grapplers
buck90 is offline
post #2 of 14 (permalink) Old 07-26-2013, 12:11 AM
Re: royal purple vs motorcraft
I ran royal purple for a while till I learned better than to waste my money. These engines shear oil. No matter what magic potion you use there is no way around it.
I run Rotella t6 in mine. Buy it by the barrel if you want to save more money and put on a lot of miles.
Oil analysis puts your mind at ease...
2K Excursion, AFEII intake, 4" straight exhaust, DP F6, 200cc singles, 38R, RR, T500, ATS stage II with 5 star tc
Balthasar is offline
post #3 of 14 (permalink) Old 07-26-2013, 12:27 AM
International Coal Roller
jbwaldrop88's Avatar
I wouldnt waste the money fr the royal purple that's gonna be sheared all to hell in 5k miles anyways iwould just run regular 15w40, I prefer valvline or delo myself, my truck runs terrible on motorcraft or rotella
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
post #4 of 14 (permalink) Old 07-27-2013, 08:41 AM Thread Starter
User Error
buck90's Avatar
exactly what I needed to know. Mine runs perfect on Motorcraft and Rotella, it's all I've ever put in it. I've been told Delo and Castrol are the worst things you can do to any engine but I suppose everyone's setup is kind of case-by-case basis and some experimenting is required to find the best brand/blend. Thanks for the advice.
buck90 is offline
post #5 of 14 (permalink) Old 07-27-2013, 10:35 AM
FL-DIESEL's Avatar
i run rotella or kendall.. good quality oil at a good price
2002 7.3 stabbin waggon ... 4in turbo back, cold air, autometer pillar, dp-tuned...more to come, feel free to make donations
FL-DIESEL is offline
post #6 of 14 (permalink) Old 08-07-2013, 08:21 PM
Been running Rotella T-6 synth in my 6.0 & 7.3, never had a prob with either. They run great.
scooter is offline
post #7 of 14 (permalink) Old 08-07-2013, 09:51 PM
Billy Big Rigger
smoking69's Avatar
Ive always ran Valvoline Premium Blue in all mine, until recently switching to Rotella T6 and never had a problem with either, Valvoline made my E99 run the best out of all the dino oils I've used. Really like this T6 though, faster and smoother starts and just feels like the truck runs smoother than on the regular oils.
97 F350, 300/200, GT4202R, Twin Walbro's, sumped F26E tank, built E4OD, ISSPRO gauges.
smoking69 is offline
post #8 of 14 (permalink) Old 08-07-2013, 10:24 PM
n00blet
Heck, my last oil change I used Mobil 1 TDT.
Are synthetics just not that great for these engines? Or do people just consider it tossing money away?
VW_Factor is offline
post #9 of 14 (permalink) Old 08-07-2013, 11:05 PM
FL-DIESEL's Avatar
everyone has their own opinions on that matter.. although the engine isnt required to have it.. save your money.. my uncles truck is fixing to turn over 500k miles on rotella oil, never an issue
post #10 of 14 (permalink) Old 08-08-2013, 03:09 PM
Most opinions and the UOA's that I've seen support the conclusion that synthetics resist shear alot better and in cold climates start up is a whole lot better, but from what I can tell both syn and dino are sheared down after about 5k miles just keep the oil changed and you'll be good, I've seen the 7.3 go 400k and climbing on rotella, I've seen one last till 680k on oil from the john Deere dealer, all at 5l mile oci. The cost of syn has always pushed me away, although I might try the new delo syn that walmart has for $ 18 a gal.
