FRx or rebuild - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-19-2013, 04:39 AM Thread Starter
FRx or rebuild
Im rebuilding my FPR because of fuel pressure problems. I was at the same time putting a billet FPR on it just in case. However im thinking about instead of the billet FPR, installing a FRx. What do you think I should do. Is the FRx worth my time and money to do. Will I notice a difference
2003 F-350 SRW 4x4 7.3, Afe Cold Air Intake, 4in Turbo Back Exhaust and Downpipe, Glowshift Gauges Pyro Boost Fuel Pressure, Superchips Max Micro, 4in Lift, Front and Rear Replacements Bumpers, Banks Wastegate, Hutch and Harpoon mod, 12,000 lb Warn Winch, Alpine Head Unit, Boss Amp, 2-12' Kicker CVT Loaded Box Subwoofers
bmw10494 is offline
post #2 of 4 (permalink) Old 07-19-2013, 11:42 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: FRx or rebuild
if you plan on bigger injectors down the road...do it once..do it right..get a full regulated return..
Ron's power stroke is offline
post #3 of 4 (permalink) Old 07-19-2013, 03:17 PM
Re: FRx or rebuild
If your not planning on bigger injectors down the road than do the frx. It works as advertised. Good mod for those not going big.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #4 of 4 (permalink) Old 07-19-2013, 09:27 PM
Village Idiot
southmike's Avatar
Re: FRx or rebuild
I thought about a modified version of diesel orings billet reg cover. But the folks there said the other unit was thicker.
If you got the clams the frx is better.
Diesel orings also sells just the spring...or someone does..
southmike is offline
