How much is too much? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 01-31-2009, 12:25 AM Thread Starter
matthewd11's Avatar
Blowby, that is. I did some tests tonight and here is what i got.
I placed the oil fill cap over the filler neck and it hovered over it and eventually vibrated back toward the back of the engine, but did not "blow" off.
Next, i used a ping pong ball and it rattled back and forth in the filler neck, but did not blow out.
I also used a golf ball and it very slowly spun in place in the filler neck.
What do you guys think? My CCV is vented to atmosphere. The truck has hybrids, H2E and other supporting mods, enough for 103 mph @ 6600 lbs or so in the 1/4. It also has 107k miles, the last 12 or so have been modded heavily.
Does this sound like my blowby is excessive? Truck still runs GREAT and has lots of power. Starts quickly, doesnt smoke.
Thanks in advance.
matthewd11 is offline
post #2 of 12 (permalink) Old 01-31-2009, 12:28 AM
Powerstroke Racer's Avatar
Re: How much is too much?
That is not a correct procedure for checking blowby.
That said hook your CCV back up and see what it does
Powerstroke Racer is offline
post #3 of 12 (permalink) Old 01-31-2009, 12:33 AM
PSDfan99's Avatar
What made you want to check for blow by? Got any compression numbers?
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #4 of 12 (permalink) Old 01-31-2009, 12:40 AM
On my stock 160k engine with ccv to atmosphere, I got zero smoke. My new engine smokes a lot.... Everyone says it is normal. Here is some vids.
It made expected power on the dyno and it runs great. Still don't know why the 160k stocker had no visible blowby. Anyways, I am done worrying about it!!!
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
post #5 of 12 (permalink) Old 01-31-2009, 01:06 AM Thread Starter
matthewd11's Avatar
Mine is similar to yours rpm-inc. I guess i shouldnt worry about it as long as it is running well, making good power, and passing CCT tests.
post #6 of 12 (permalink) Old 01-31-2009, 01:07 AM Thread Starter
matthewd11's Avatar
I was just curious.
No compression numbers, dont have an absolute need for them yet i suppose. Unless it starts running like crap or gets to be low on power and/or long cranks, i'm gonna not worry about it and leave it alone.
post #7 of 12 (permalink) Old 01-31-2009, 03:20 AM
All done now
Arisley's Avatar
Mine, with 249,2XX miles, has almost no blowby??????????????????????
Arisley is offline
post #8 of 12 (permalink) Old 01-31-2009, 06:55 AM
That could just be from engine vibration while it is running. I would not worry about it, as mine does something similar.
With my CCV hooked up, if I flip the oil cap over, the cap will slowly slide off the neck towards the back of the engine compartment. I also see a mist coming out of the neck and the CCV if I disconnect it. I had a compression check done around the same time and the numbers were very good.
01 7.3L 152K miles - Alliant AC injectors, ITP regulated return, AIS, bellowed up-pipes, DP tuning, JW trans, DC Power 185A Alternator
darkstar is offline
post #9 of 12 (permalink) Old 01-31-2009, 11:14 AM Thread Starter
matthewd11's Avatar
RPM is that second vid of the filler neck with the ccv hooked up?
post #10 of 12 (permalink) Old 01-31-2009, 11:55 AM Thread Starter
matthewd11's Avatar
Ok i plugged the ccv vent tube and used the oil cap on the filler neck and it hovered there for a second or two and slid backwards off of it. The engine is on a fairly steep angle leaning backwards. Not sure if this had anything to do with it??
