Whats my Icp/Ipr numbers mean? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 07-17-2013, 03:26 AM Thread Starter
Need a little help deciphering my icp/ ipr numbers.
Econo Tune = Icp max 3000, Ipr max 52%
All out tune= Icp max 2600 Ipr max 76%
Im thinking hpop is getting week but the econo tune numbers are confusing me. Why am I getting 3000 max at 52% when in all out Im seeing 2600 max at 76%.
It defiantly falls on its face at times in all out. Havent had a chance to data log just observation while driving on way home today. Any thoughts?
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #2 of 9 (permalink) Old 07-17-2013, 09:16 AM
Village Idiot
southmike's Avatar
Re: Whats my Icp/Ipr numbers mean?
Simplified answer is it is running 76% full throttle and the best it can do is 2600 psi. With a lighter load it is working 56% but can do 3000.
Do you set any lights..
Mine was more noticable with a 15 pump. It would hit 63% and only muster less then 2000. You could feel a lack of steam. It set lights.
southmike is offline
post #3 of 9 (permalink) Old 07-17-2013, 11:10 AM
the stryker god
PW is longer in the all out tune causin less restriction. Pumps create flow, restriction creates pressure so you have the longer PW and the pump can't keep up. 76% means that the hpop is workin at 76% of max capacity.
bruce51d is offline
post #4 of 9 (permalink) Old 07-17-2013, 02:09 PM Thread Starter
Thank you makes sense.
02 F350 CC DRW 4X4.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
post #5 of 9 (permalink) Old 08-04-2013, 03:27 AM Thread Starter
Just towed 8500 lbs + up to northern Michigan
80 hp php tow tune, decent hill, accelerating up, icp was around 2250 and watched icp get up to 85% duty cycle before I let out at top of the hill. Is there anything I should double check before springing for a pump?
02 F350 CC DRW 4X4.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
post #6 of 9 (permalink) Old 08-04-2013, 04:20 AM
the stryker god
Since the injectors are new I doubt it would be poppet's or torn o-rings. You could also check for desired PW in said tune but its prolly just a worn out pump
bruce51d is offline
post #7 of 9 (permalink) Old 08-04-2013, 01:04 PM
RyanG85's Avatar
Have you checked the ICP harness for oil? Also, IPR could be weak. I would try a know good one before suspecting the HPOP.
2001 F250 ECSB (FOR SALE)
Walker BTM
2001 F350 CCSB
Ford AIS with Zoodad mod & Sleeve
Dorman Bellowed Uppies
Autometer Factory Match
Terminator T500
Hutch and Harpooned
CCV Mod
PHP Hydra
BTS Valve Body & PI Stallion
Diamond Eye 4" Turbo Back
Riff Raff Billet Wheel and FRX
RyanG85 is offline
post #8 of 9 (permalink) Old 08-05-2013, 03:46 PM
Village Idiot
southmike's Avatar
It means you want a better hpop
post #9 of 9 (permalink) Old 08-06-2013, 02:42 AM Thread Starter
Ya IPR functions fine. Good numbers regular driving, only have gotten high IPR in gear head all out doing a wot run and the one time going up this trip in tow tune. Tried to make it do it coming back and couldn't.
Just wanted to make sure I wasn't forgetting to check something
02 F350 CC DRW 4X4.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
