80s idi tranny in 99 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-15-2013, 03:46 AM Thread Starter
bubbathompson2010's Avatar
OK ditched the auto, now i need definative answer from someone who HAS swaped a idi 5 speed into an auto powerstroke, is there a bell housing issue? and all i need is a powerstroke clutch n flywheel right.... Im away from my shop otherwise Id check myself and all the other issues have already been taken care of such as tranny height and clutch pedal, pcm, master and slave cylinder. Any Info would be appriciated
bubbathompson2010 is offline
post #2 of 4 (permalink) Old 07-15-2013, 05:26 AM
94.5 Stroker's Avatar
Re: 80s idi tranny in 99
Why would you put an idi trans in? It is a lot weaker than a PSD zf5 out of an obs or why not just do a zf6 out of superduty for a direct swap?
95 F250 RCLB- super duty axles, PMF RSK, PMF adjustable track bar, v codes, air bags, hydro boost, intercooled.
Sold: 94.5 ECLB 08 ECLB
94.5 Stroker is offline
post #3 of 4 (permalink) Old 07-15-2013, 10:01 PM Thread Starter
Didn't read above did you?? I was asking for specific information not something you heard, if your reffering that the zf5-42 has 50 ft pounds less of rated torque its quite irrelevant considering the trucks use, so that aside If anyone actually knows and yet again HAs done it let me know.....
post #4 of 4 (permalink) Old 07-16-2013, 11:53 PM
Village Idiot
southmike's Avatar
quick answer is no.
it seems the idi is taller and will hit the body.
as well as possibly having a different bolt pattern
Powerstroke ZF5 to a IDI truck?
Powerstroke vs IDI transmission question - The Ranger Station Forums
E4OD powerstroke to IDI swap - Diesel Bombers
southmike is offline
