fuel pressure problems help!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 07-14-2013, 08:26 PM Thread Starter
7.3_geek_124's Avatar
Just installed my swamp injectors and frx in my truck, was losing fuel pressure, so I put a new fuel pump in and dropped the tank and my pickup was pretty clean. And now have no idea why I keep losing pressure, it's fine when it first starts up but after I drive a few miles and try to get in it. It just drops to 0 and dies on me, anybody have any ideas?
Late model 99 ext cab - Exterior: 05 front end, 08 mirrors, 08 tail gate, 10 inch skyjacker lift on full springs, 22x13.50 moto metal 962's wrapped in 37" Toto mt's.
Engine: swamps 160/100 sticks, turbonetics turbo with a 63/91 comp wheel, gauges, riffraff ocr, riffraff intercooler boots, ts 6 pos chip.
7.3_geek_124 is offline
post #2 of 18 (permalink) Old 07-14-2013, 08:52 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: fuel pressure problems help!!
try a real regulated return....
Ron's power stroke is offline
post #3 of 18 (permalink) Old 07-14-2013, 09:14 PM Thread Starter
I don't feel like that's the problem, plenty of guys are running just an frx and don't seem to be having the same problem.
post #4 of 18 (permalink) Old 07-14-2013, 09:26 PM
Have you checked the fuel lines where they hook into the cylinder heads for leaks. You are supposed to replace those sleeves every so often because the can cause good leaks.
2003 F-350 SRW 4x4 7.3, Afe Cold Air Intake, 4in Turbo Back Exhaust and Downpipe, Glowshift Gauges Pyro Boost Fuel Pressure, Superchips Max Micro, 4in Lift, Front and Rear Replacements Bumpers, Banks Wastegate, Hutch and Harpoon mod, 12,000 lb Warn Winch, Alpine Head Unit, Boss Amp, 2-12' Kicker CVT Loaded Box Subwoofers
bmw10494 is offline
post #5 of 18 (permalink) Old 07-14-2013, 10:10 PM
Busy Busy
Marty's Avatar
If the sleeves are leaking, they will create an external leak.
You need to start by finding out what the pressure is right at the pump. If you have 0 psi at the pump after some time, you need to remove the pickup, and put a line from a bucket of fuel to the pump. Then retest.
Report back after doing this...
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #6 of 18 (permalink) Old 07-14-2013, 11:39 PM
codykthekilla's Avatar
Garage
Yeah you need to find out what you have at the pump and if its not enough you need to put a restriction gauge on the inlet side of pump if you can get one. Any more than 6Hg at WOT and you have a restriction. Did you look at just the screen on the pick up? If so you probably did no see a restriction as it would be on the socks of the inside of the pickup. If you take some small screw drivers or picks you can wedge them in the seam at the bottom of the housing and it will come out with a little finess. Then just take some brake clean and spray them off and reinstall. Just be careful not to break housing when coming apart
2002 F-250 CCSB PSD 4X4, 38R, S&B CAI, Bully Dog GT, 4" Exhaust, 05 head lights and grill, 08 power fold mirrors, tailgate, bumper, tail lights, 2014 chrome steps.
1979 Bronco 4X4, 460, c6, 205
2003 Ranger 2.3 MT 2wd
codykthekilla is offline
post #7 of 18 (permalink) Old 07-15-2013, 06:50 PM Thread Starter
Well after I checked everything in my tank I put everything back together and also checked my spring and made sure I was getting fuel into my bowl.. after everything was back in I started it up and all of a sudden had 90 psi of fuel pressure drove it around the block dropped to about 80 psi and just cut off randomly..
post #8 of 18 (permalink) Old 07-15-2013, 09:53 PM
dadada's Avatar
90 psi or even 80 psi fuel pressure will do some serious damage to those injectors. If you are running a Walbro fuel pump, you cannot run a FRx kit because the springs will not work. Stock fuel pump with that kind of fuel pressure, then your spring in the FRx kit is in a bind probably. I had a FRx kit and went to a regulated return.
2001 F-250 4X4 SCSB 7.3 Auto X Codes w/ 2" Hanger/Shackle Drop Kit-38R w/Turbomaster,AFE, T500, Regulated Return, 6.0 Tranny Cooler, JWVB, 4"Exhaust, Hydra w/ Gearhead, PHP, and Powerstruck tunes, Powerstruck 180/100's Live Tuned by Powerstruck and then some!
dadada is offline
post #9 of 18 (permalink) Old 07-16-2013, 04:25 PM Thread Starter
That's what I was affraid of.. ya I was using a stock fuel pump... So did you have any problems with the frx?
post #10 of 18 (permalink) Old 07-16-2013, 06:32 PM
Village Idiot
southmike's Avatar
what color spring did you use in the frx..they had one that will go that high.
southmike is offline
