PCM/Chip Issue NEED HELP! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 07-13-2013, 10:37 PM Thread Starter
too broke to play
Cmonster's Avatar
I recently fried my PCM (long story). I had a new one put in and life has been good again. I took it out today to put my chip back in, and now the main plug in the engine compartment won't plug in. No matter what I do, I can't get the plug to seat.
I've tried with and without the plastic bracket, but something in the plug or computer isn't matching up it seems.
Do any of you have any ideas or have seen this before and know a trick to get it to go. It will start but not seat.
I need my truck back on the road. This was supposed to be a simple 1 hour job that has turned into an all day problem.
Thanks for any help.
Jim
2003 F-250, CC, SB, 4x4, 7.3, 6 speed
Cmonster is offline
post #2 of 9 (permalink) Old 07-13-2013, 10:57 PM
ToMang07's Avatar
Re: PCM/Chip Issue NEED HELP!
Jim
My guess is the PCM is upside-down. Which side is the stamped "X" on?
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, PHP Phoenix-(STK-80dd-100P-120R-65T-40T) 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, Fisher 8' MM2. Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203*TS and Billet Housing, ELC, Fumoto, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing...~AE w/Ford Pack~
ToMang07 is offline
post #3 of 9 (permalink) Old 07-13-2013, 11:30 PM
01 SmokeChoke's Avatar
damn thats odd. Heres a bump but if I were to give my own opinion I'd say the same thing as ToMang did. Any bent pins? Just take your time dont get frustrated and mess up something expensive.
IH Crate Engine,Cold Air,4" MBRP,6.5" lift,37" toyos,mx6 resis,Water meth,Stage 1s,Turbo Master,38R,6.0 CAC,6.0 trans cooler,FRx, Intank Mods,pre pump filter,AIH&EBPV deletes,Zoodad,456 yukon gears,Ladder bars,built trans,Aeroforce interceptor,quad pillar,PHP HYDRA,IH up pipes,Forged Rods
01 SmokeChoke is offline
post #4 of 9 (permalink) Old 07-13-2013, 11:59 PM Thread Starter
too broke to play
Cmonster's Avatar
Well I got the pcm to connect enough to run, but it still seems like the plug should go in all the way. Not sure about that. Thanks for the ideas. Upside down was my first thought too. I checked and the plug only inserts one way. It was right, just doesn't look the way it should even now that it is running.
Cmonster is offline
post #5 of 9 (permalink) Old 07-14-2013, 12:21 AM
ToMang07's Avatar
I'd pull it then and check for bent pins.
ToMang07 is offline
post #6 of 9 (permalink) Old 07-14-2013, 02:01 AM
97250HD's Avatar
Maybe something wedged between the connector and the PCM. Like ToMang07 pull it again and see if anything is askew.
97 F250 eclb. 265k
- Fresh engine. d60. zf5. Some other stuff...
E99 f550 213k
- starts every morning...
97250HD is offline
post #7 of 9 (permalink) Old 07-14-2013, 02:42 AM
dsberman94's Avatar
When I put mine in a get it on enough to get the bolt to start threading and use the bolt to get it the rest of the way on after screwing the PCM in where its supposed to go. Next for you would be check for bent pins as stated above.
02
F250 7.3 Crew Cab Short Bed Lariat
4"dp 5 inch pipes to dual 8 inch stacks (summer)
4" turbo back dual axle dumps (winter)
PHP Hydra (loaded)
Edge insight CTS monitor w/ eas system
17 ton d-ring with solid polished titanium hitch
80% over rosewood injectors
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
dsberman94 is offline
post #8 of 9 (permalink) Old 07-14-2013, 03:11 AM
Village Idiot
southmike's Avatar
prob a bent or misaligned pin.
southmike is offline
post #9 of 9 (permalink) Old 07-14-2013, 04:18 PM
RyanG85's Avatar
Sometimes the rubber seal can cause problems. I usually spray a little white lithium grease on the rubber seals on all connectors to get them to seat correctly.
2001 F250 ECSB (FOR SALE)
Walker BTM
2001 F350 CCSB
Ford AIS with Zoodad mod & Sleeve
Dorman Bellowed Uppies
Autometer Factory Match
Terminator T500
Hutch and Harpooned
CCV Mod
PHP Hydra
BTS Valve Body & PI Stallion
Diamond Eye 4" Turbo Back
Riff Raff Billet Wheel and FRX
RyanG85 is offline
