dp tuner 99 into 2002 ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-13-2013, 05:47 PM Thread Starter
slow learner
Jbolen323's Avatar
Send a message via MSN to Jbolen323 Send a message via Skype™ to Jbolen323
got my hands on a dp tuner that was in a 99 my question is can i put it into my 2002 ? Well with that being said i already did try it but my rpm gauge wasn't working and my a/c wasn't blowing cold and i had a check gauge + engine light pop on... but it ran perfect.
Do i need to get it reflashed ? or is it because of the pcm ? Also would it benefit me to just swap the pcms since i have both trucks ?
just curious since dp is closed till monday.
2002 built forged7.3 350/200%| t4 w s468 | gearhead| BTS trans | 20* MB hpop| 6.4 conversion | 05 axle + 4link |PMF susp|
e1999 Tow pig 7.3 FF 160/100 | t4 w BASB Bell turbo | gearhead | adrenaline hpop| John woods Race trans|300k|
2003 ccsb stock 52k original owner.
Jbolen323 is offline
post #2 of 6 (permalink) Old 07-13-2013, 10:59 PM
ToMang07's Avatar
Re: dp tuner 99 into 2002 ?
Well, if you INSIST on using DP...
Yes, you should have it flashed, as the PCM codes will be different.
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, PHP Phoenix-(STK-80dd-100P-120R-65T-40T) 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, Fisher 8' MM2. Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203*TS and Billet Housing, ELC, Fumoto, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing...~AE w/Ford Pack~
ToMang07 is offline
post #3 of 6 (permalink) Old 07-13-2013, 11:24 PM Thread Starter
slow learner
Jbolen323's Avatar
i don't insist on using anyone, ive always have heard nothing but great things for dp ,php , and tony as ive been reading for a while, i just happened to come across a truck i purchased with a tuner already.
and im a very huge fan of the custom tunes, now that i actually got to see one in action and play with it ill be setting up my other trucks asap.
post #4 of 6 (permalink) Old 07-14-2013, 03:19 AM
Village Idiot
southmike's Avatar
They are very different pcm codes it needs a reflash.
you want newer tunes anyway they are all around better, and a reflash will be your cheapest route.
Now that you mention it I haven't heard of any trucks blowing lately, from anyone's tunes really.
Jody's crew will get you fixed up quick.
southmike is offline
post #5 of 6 (permalink) Old 07-15-2013, 04:54 AM
tbolt's Avatar
Send Jody the chip & pcm and he'll fix you up. I've had his tunes for several yrs now and no issues towing heavy. I wasn't building a hotrod just a tow mule.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #6 of 6 (permalink) Old 07-16-2013, 01:23 AM
I believe I talked with you today. If not, feel free to call us.
Yes, you will need it reflashed for the 2002. L99-01 were different than the 02-03 PCM's.
