van turbo help. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-11-2013, 09:12 PM Thread Starter
hotrodhoward's Avatar
van turbo help.
I was thinking about potting a van turbo on my superduty to try and get egt's a little lower. Would love a 38r but don't have the money right now. Is it worth it. If so does anyone have one for sale near Ohio. I live north of Cincinnati. Thanks in advance.
2000 f250 EX SB 4x4 zf6 speed w/ south Bend 3250 dd, riff raff OCR, riff raff frc, riff raff oil crossover, PHP 6 position chip 6637 air filter, glow shift 3 in 1 gauge, 4" down pipe with 5" exhaust.
hotrodhoward is offline
post #2 of 8 (permalink) Old 07-11-2013, 11:16 PM
old Smokey's Avatar
Re: van turbo help.
I did like the ww2 to help some for egt's. I did a van turbo on my obs. On yours I do not know if there is going to be a big difference. The exhaust housing on the van turbo is 1.15. If you have a .84 or 1.10 it would help.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #3 of 8 (permalink) Old 07-11-2013, 11:34 PM Thread Starter
Re: van turbo help.
Would it be better to just put a ww2 in my turbo or do the van turbo with ww2?
post #4 of 8 (permalink) Old 07-11-2013, 11:37 PM
mtray's Avatar
Re: van turbo help.
Well your sacrificing spool up with the bigger exhaust housing on the van turbo but your gonna get lower egt. You throw a ww2 on the van turbo it'll help a lot with spool up so if it was me I would do the ww2 on the van turbo
2000 Ford F250 7.3 4x4. MODS: Beans Tunes, Jegs 4" exhaust, S&B intake, boost fooler, USA poted housing, RR billet wheel for ported housing, HFO, glowshifts 3-in-1 gauge pyro, boost, trans. AIH delete, bellowed uppipes, Sinister Diesel coolant filter.
mtray is offline
post #5 of 8 (permalink) Old 07-12-2013, 02:27 AM
Re: van turbo help.
Im currently running a ww2 on a van turbo and the spool up is about the same as when I had a completely stock turbo if not a little better. Egts are a bit lower just driving however I haven't towed with it yet which will be the true test.
Theres a used van turbo for sale on craigslist up in Michigan.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #6 of 8 (permalink) Old 07-12-2013, 08:08 AM
tonka350's Avatar
Re: van turbo help.
Barnhartal where at in michigan??? I'm looking for one as well!
Chad
00 F350, 08 clone, 3" cowl hood,billet grilles, 15" lift, 40" SS M16'S, 24X12 Rockstars, 2% tint, EBPV Delete, 4" duals w/7" tips, 6637 intake, WW, CCV Mod, PHP 80,120 race,140 Extreme, stage 1 single shots, 6.0 I/C
Chad
tonka350 is offline
post #7 of 8 (permalink) Old 07-12-2013, 04:02 PM Thread Starter
Re: van turbo help.
What all do I need to install a van turbo on my truck? Or should I just throw a ww2 in the stocker?
post #8 of 8 (permalink) Old 07-12-2013, 04:19 PM
Re: van turbo help.
Only thing you need to install a van turbo is a truck outlet adapter.
I went with van turbo cause I am broke and needed to lower my egts when towing also needed to go bigger than the .84 exhaust housing to get rid of the engine brake effect.
7.3l powerstroke turbo diesel TURBO CHARGER/ECM and ALTERNATOR!!!
02 F350 CC DRW 4X4.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
