Ceramic coating up pipes, turbo outlet, turbo exhaust, manifolds, IC, spider intake?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-11-2013, 02:31 PM Thread Starter
needinajeep's Avatar
I am replacing the up pipes due to leaks, ^ EGTs, and low boost.
Found a local powercoater specializing in ceramic coating. I plan having the up pipes and collector done. His prices are very reasonable. So I'm considering having more done since the turbo and up pipes will be out and Ill have more room to pull down pipe. Heck I have to pull all out it anyway.
Should I have the new blank outlet coated? Or 4" stainless down pipe? Exhaust turbo housing? Exhaust manifolds? I think cost will be very reasonable. I also thought about power coating or ceramic coating the IC tubes and intake??
Fyi- I am also installing a hydra chip, regulated return with bowl delete, spin on fuel filter after pump, trans spin on filter, FASS 150gph low pressure, WW2, non-ebpv pedestal, and non ebpv outlet, IC boot kit and plenum inserts/tclamps
Original thread - towing upgrade
towing upgrades - PowerStrokeNation : Ford Powerstroke Diesel Forum
1999.5 CC LB dew 2wd 7.3 GTP38R, PHP hydra chip and tunes, regulated return kit w fuel bowl delete, 4" Turbo-Back Magnaflow Exhaust, Riffraf tymar intake, riffraff intercooler boot set and clamps, 6.0L Trans. Cooler, BTS V/B, Foil MOD, CCV Mod, HPX, Gauges- CS Insight, Mag-Hytec Trans & Diff Cover, new IH up-pipes, external fuel and trans filters
needinajeep is offline
post #2 of 8 (permalink) Old 07-11-2013, 02:39 PM
jtgf250's Avatar
Re: Ceramic coating up pipes, turbo outlet, turbo exhaust, manifolds, IC, spider intake??
If it were me I'ld do the exhaust manifolds, up-pipes, collector and turbo exhaust housing. Maybe the down pipe if it were cheap enough.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #3 of 8 (permalink) Old 07-11-2013, 04:11 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
It doesnt do much. Looks pretty for a few months and then begins to fade.
If the price is right fine, but dont expect to gain much.
Joe
CSIPSD is offline
post #4 of 8 (permalink) Old 07-11-2013, 04:58 PM
geared_low550's Avatar
Send a message via AIM to geared_low550
A duramax buddy of mine did this to his along with a turbo blanket , told me it helped him spool quicker. Is he tellin the truth ? Or was he misinformed a bit?
08 250= sold
2005 CCSB 6.0= sold
2011 CCLB 350 dually lariat, 4x4, 6.7 all stock
95 ex cab long bed f250,4x4,7.3 auto with 4.10s and swamps tuning, 3 inch dp.for sale!!!
2002 ex cab long bed 4x4 7.3 auto. Stock and 294k on the clock.
geared_low550 is offline
post #5 of 8 (permalink) Old 07-11-2013, 05:07 PM
CSIPSD's Avatar
He spent $300 or more on it... Would you spend that much and then not get a nice placebo effect and think it feels better...
You MIGHT pick up a bit of spool, but at the stock HP level, it will not be enough to notice.
My exhaust housings are always coated, just cleaner... Otherwise I dont notice anything.
Joe
CSIPSD is offline
post #6 of 8 (permalink) Old 07-11-2013, 05:54 PM Thread Starter
Yeah I figured it wouldn't make a big diff other than longevity and bling factor. How difficult is it to remove exhaust manifolds?
post #7 of 8 (permalink) Old 07-11-2013, 06:29 PM
7.3
7.3's Avatar
i would imagine taking the manifolds off just for powder coating isnt worth the hassle. prob brake off most the nuts from rust.. id just do what youre taking out of the truck to replace. wouldnt mess with other things.
7.3 is offline
post #8 of 8 (permalink) Old 07-11-2013, 09:02 PM
Depends on the amount of rust on the bolts. Here in MN after 12 years I can't imagine the job it would be to R&R the exhaust mans in frame. I rebuild a PSD maybe 5 years ago, a '96 year and a sawzall came in really handy....and then IHC bent me over from new hardware. Ford was worse.
'01 F250 4x4 Crew Shorty, PM Rods, PIS 160/30's , Hydra, BW 364.5SXE, Monster Box, MBRP 4" 409 SSTL Exhaust, Firestone Ride-Rights, Regulated fuel return.
Dan V is offline
