Motor Build - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 35 (permalink) Old 07-11-2013, 08:11 AM Thread Starter
Homesteader's Avatar
Motor Build
Anyone did their own motor build and overhaul for High HP ?
Homesteader is offline
post #2 of 35 (permalink) Old 07-11-2013, 08:14 PM
Village Idiot
southmike's Avatar
Re: Motor Build
how high ..killapapia had a great thread on his , vander chevy etc.
southmike is offline
post #3 of 35 (permalink) Old 07-12-2013, 01:02 AM Thread Starter
Re: Motor Build
650+ maybe little more
post #4 of 35 (permalink) Old 07-12-2013, 01:21 AM
mtray's Avatar
Re: Motor Build
There might be somebody on here but if your looking form that high of HP number I would check out PSA
2000 Ford F250 7.3 4x4. MODS: Beans Tunes, Jegs 4" exhaust, S&B intake, boost fooler, USA poted housing, RR billet wheel for ported housing, HFO, glowshifts 3-in-1 gauge pyro, boost, trans. AIH delete, bellowed uppipes, Sinister Diesel coolant filter.
mtray is offline
post #5 of 35 (permalink) Old 07-12-2013, 01:26 AM
Village Idiot
southmike's Avatar
Re: Motor Build
Killapapias build plus crower rods, coated dished mahles, ati balancer, girdle.
Much more headwork port polished with hypermax valve setup, Headers....
Add bigger turbo, injectors and big oil..custom tunes and dyno time.
Really should look at powerstrok army site once your 600.
Knowledge pool of been there done that is larger.
But basically money ..money and more money.
But if you can find specs on thuglikes truck iirc it lived quite some time at 658plus.
Marty was above six hundred as well.
Just my two cents
post #6 of 35 (permalink) Old 07-12-2013, 07:06 AM
Re: Motor Build
A couple.
Time to use the search feature.
TerminatorEngineering is offline
post #7 of 35 (permalink) Old 07-23-2013, 08:40 PM
Busy Busy
Marty's Avatar
Re: Motor Build
I went 115.76 @ 7400 lbs.
Equates to: 779 rwhp.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #8 of 35 (permalink) Old 07-23-2013, 08:47 PM
geared_low550's Avatar
Send a message via AIM to geared_low550
Re: Motor Build
nice number ! No wonder your name is brought up so much
08 250= sold
2005 CCSB 6.0= sold
2011 CCLB 350 dually lariat, 4x4, 6.7 all stock
95 ex cab long bed f250,4x4,7.3 auto with 4.10s and swamps tuning, 3 inch dp.for sale!!!
2002 ex cab long bed 4x4 7.3 auto. Stock and 294k on the clock.
geared_low550 is offline
post #9 of 35 (permalink) Old 07-23-2013, 10:46 PM
Village Idiot
southmike's Avatar
Re: Motor Build
on a stock bottom iirc not sure if he runs a girdle or block filled either..
post #10 of 35 (permalink) Old 07-24-2013, 12:28 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: Motor Build
I tried to build my own engine back in 09. I thought i knew ENOUGH, turns out i knew a "good bit", but lacked attention to detail in areas i didnt knew there was something important i was missing. I could have dropped all my parts off at a shop that does it for a living and been well ahead in time and money if i let them do it right the first time. But on the other hand it was a good learning experience, but very expensive. Let someone else do it.
Stock
PowerstrokeJunkie is offline
