Just purchased AE Pro Bundle. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-16-2007, 10:07 PM Thread Starter
PwrStrokinDually's Avatar
Send a message via AIM to PwrStrokinDually
Just placed the order today for the Auto Enginuity Pro Bundle. Bought the pro bundle because I would've spent only a few hundred bucks less to cover all the vehicles in my driveway. Also, if any members near me or during a tech day needs help with other vehicles other than Ford I could also help them out so I figured it's money well spent. Now, what parameters should I be constantly viewing at on my powerstroke? And how simple is it to use compared to Ford's NGS scan tool?
Danny Om
01 SC PSD Dually (build date 08-00 w/ PMRs), 8" Edge, dual F&R Doetsch aluminum shocks w/ resevoirs, 37" SSR on all 6 tires, 2" (hub & wheel centric) wheel adapters by Fearless Fred Goeske, Fabtech racing track bars.
Fully built motor w/ B-codes, GT42R, and Terminator w/ Remote IPR HPOS.
PwrStrokinDually is offline
post #2 of 13 (permalink) Old 10-16-2007, 11:35 PM
OEM Moderator
Tom S's Avatar
Re: Just purchased AE Pro Bundle.
Well one of my starting points is to compare manifold absolute, exhaust back pressure and baro to each other with key on motor not running. They should all read similar at 14 psi or so at sea level. Some chip programs can fool the manifold pressure though.
Tom
Tom S is offline
post #3 of 13 (permalink) Old 10-20-2007, 09:05 AM Thread Starter
Once AE is installed, do I need to leave the CD in the drive or can I leave that at home now?
Danny Om
post #4 of 13 (permalink) Old 10-20-2007, 10:48 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
You have to leave the DVD in the drive whenever you want to run the program.
Parameters i watch most are ICP duty cycle, injection control pressure, RPM (relate them, you can put two parameters on one histograph and compare them), and as said, MAP, EBP and BARO.
Stock
PowerstrokeJunkie is offline
post #5 of 13 (permalink) Old 10-20-2007, 03:56 PM
Corona Killa
THEDIESELMAN's Avatar
I don't have to have the CD when I'm use AE.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #6 of 13 (permalink) Old 10-20-2007, 04:00 PM
<- Sums it up
strokin_early_99's Avatar
Nope. At least mine works just fine without the disk.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #7 of 13 (permalink) Old 10-20-2007, 05:12 PM
Starting Over
kainers's Avatar
bought time danny money well spent.Remember you only get 3 requests for new pins on new installs.1 year support then 50 bucks for another 3 request for pins.
I don't know why you would have to leave the disk in.Something new.
kainers is offline
post #8 of 13 (permalink) Old 10-20-2007, 11:17 PM Thread Starter
Now what exactly are the 3 Pins? Are they like updates? And how will I know when there are new updates available? Will they email me?
Danny Om
post #9 of 13 (permalink) Old 10-20-2007, 11:42 PM
Bigfoot is an OBS
cowboy_dan's Avatar
The newer versions will let you reinstall if your computer crashes. Installation requires a pin. More like a password than a PIN, actually.
It also allows you to sell the original bundle when you're done with it and the purchaser can install it on their computer.
Go ARMY!
cowboy_dan is offline
post #10 of 13 (permalink) Old 10-21-2007, 03:56 AM
All done now
Arisley's Avatar
Wow, I am used to being able to reinstall a program on my computer as many times as neccessary, and programs I have that are way more bucks than AE come with FREE upgrades for LIFE.
Arisley is offline
