6637 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 07-03-2013, 03:47 AM Thread Starter
6637
wondering if anyone can post pictures of who they set up their 6637 diy filter setup. I'm looking at making one and just need something to go off.
erstroke is offline
post #2 of 20 (permalink) Old 07-03-2013, 04:07 AM
Re: 6637
Do a search for "DIY Tymar" on this site and others, you'll get plenty of pictures.
Early 99 F-250 XLT Extended Cab 4x2. XLE4 PCM, BTS Transmission, pre pump fuel filter,CCV Mod, DIY TYMAR, Coolant Filter, 48 Gal Transfer Flow Mid-Ship Fuel Tank
FleetMan is offline
post #3 of 20 (permalink) Old 07-03-2013, 04:10 AM
Re: 6637
If you want a DIY as easy as it gets just order RiffRaffs kit. The few pennys you save in rounding up parts will cost you way to much time running around.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #4 of 20 (permalink) Old 07-03-2013, 02:52 PM
ToMang07's Avatar
Re: 6637
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, PHP Phoenix-(STK-80dd-100P-120R-65T-40T) 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, Fisher 8' MM2. Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203*TS and Billet Housing, ELC, Fumoto, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing...~AE w/Ford Pack~
ToMang07 is offline
post #5 of 20 (permalink) Old 07-03-2013, 02:57 PM
Re: 6637
Originally Posted by ToMang07 View Post
Did you rattlecan those IC pipes or is that powdercoated?
2000-7.3L is offline
post #6 of 20 (permalink) Old 07-03-2013, 03:06 PM
ToMang07's Avatar
Re: 6637
Ceramic header paint, rattle can. It was *supposed* to be red. -_-\
ToMang07 is offline
post #7 of 20 (permalink) Old 07-03-2013, 03:11 PM
Re: 6637
Thats the chevy small block orange
post #8 of 20 (permalink) Old 07-03-2013, 03:43 PM
ToMang07's Avatar
Re: 6637
Like I said.... it was supposed to be red.
ToMang07 is offline
post #9 of 20 (permalink) Old 07-03-2013, 06:17 PM
Re: 6637
I just installed my filter last weekend. I bought the Donaldson B085011 and a 4-1/2" hose clamp. I installed a 4" turbo back at the same time which I installed a tip on. This required me to cut some of the tail pipe off. I used a 3" long piece of the 4" exhaust pipe to connect the filter. I ended up removing some of the lower half of the stock airbox to help fit the filter. Painted the pipe black and here it is.
Nitsud300 is offline
post #10 of 20 (permalink) Old 07-03-2013, 09:09 PM
Bobs 7.3
Bobs 7.3's Avatar
Re: 6637
I have the riffraff kit with the sock and it works great and took a half hr to install. Most of the time was cutting the stock airbox pieces out of the way for the filter to fit without rubbing anything.
Bobs 7.3 is offline
