174/173's, 38r, 28psi????? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 01-23-2009, 01:47 AM Thread Starter
Keyboard Thug
Big Bore's Avatar
I think I have a boost leak. I've never been able to get over 30 psi. How do I go about checking for leaks etc?
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
Big Bore is offline
post #2 of 13 (permalink) Old 01-23-2009, 02:14 AM
<----Colin Banks
mattymx's Avatar
Re: 174/173's, 38r, 28psi?????
Make a tool like I did and fill the system to 15PSI. Get a spray bottle with soapy water and spray every boot, line, and tube in the intake system. Look for bubbles. This installs on the intake tube in place of your air filter.
mattymx is offline
post #3 of 13 (permalink) Old 01-23-2009, 02:16 AM
Super Hauler!
Super_Hauler's Avatar
yep.
Super_Hauler is offline
post #4 of 13 (permalink) Old 01-23-2009, 02:18 AM
<----Colin Banks
mattymx's Avatar
Oh and by the way. Dont seal this tool with silicone. I did the first time I built it and it blew up. JB Weld fixed that. And also dont fill the system over 15PSI. It can pop off and do some damage.
mattymx is offline
post #5 of 13 (permalink) Old 01-23-2009, 02:34 AM
mflores's Avatar
How fast should it leak off?
Early 99 Ford F-350 4X4, Extended Cab, Dually, 4 in lift, 6spd, Guages, Dual 5 in stacks, Gutted ebv, Ts chip, Zoodad, Ccv, Tymar, Stealth Duals, Modded IDM, South Bend Clutch, 262,000 miles
2001 Ford Excursion 4X4, Auto, Guages, dual 4 in Exhaust, zoodad, 2.5 in lift, 102,000 miles Everything else stock
mflores is offline
post #6 of 13 (permalink) Old 01-23-2009, 02:44 AM
<-- it's like that
I have a leak detector if you want to borrow it.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #7 of 13 (permalink) Old 01-23-2009, 03:02 AM
<----Colin Banks
mattymx's Avatar
The best I have got is about 15PSI in about 30 seconds or so.
mattymx is offline
post #8 of 13 (permalink) Old 01-23-2009, 11:55 AM Thread Starter
Keyboard Thug
Big Bore's Avatar
Hey man, absolutely, I would love to. I'll call you next week. Otherwise I think I probably need to make one like Matty said.
Big Bore is offline
post #9 of 13 (permalink) Old 01-23-2009, 02:54 PM
OEM Moderator
Tom S's Avatar
I also have one Frank.
Tom S is offline
post #10 of 13 (permalink) Old 01-24-2009, 03:52 PM
Sponsor
Frank, 28-30 PSI is where the wastegate typically blows open due to the exhaust pressure overcoming the diaphram spring and forcing the valve open. (Even if you have disconnected the pressure lines to the valve)
Jonathan
Early 99 7.3, Gen3 HPOP, 175/146 Inj's, PI converter
Custom 7.3 Tuning w/ Cylinder Pressure Testing
Advanced Vehicle Diagnostics & Troubleshooting
Swamp is offline
