loss of fuel pressure?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 32 (permalink) Old 06-29-2013, 12:38 AM Thread Starter
7.3_geek_124's Avatar
Everytime I accelerate my fuel pressure drops down to like 50 or 30 and when I put my gut in it, it drips to 0.. bad fuel pump or something else? I have the stock fuel pump in
Late model 99 ext cab - Exterior: 05 front end, 08 mirrors, 08 tail gate, 10 inch skyjacker lift on full springs, 22x13.50 moto metal 962's wrapped in 37" Toto mt's.
Engine: swamps 160/100 sticks, turbonetics turbo with a 63/91 comp wheel, gauges, riffraff ocr, riffraff intercooler boots, ts 6 pos chip.
7.3_geek_124 is offline
post #2 of 32 (permalink) Old 06-29-2013, 01:12 AM
dadada's Avatar
Re: loss of fuel pressure??
I would go with fuel pump going.
2001 F-250 4X4 SCSB 7.3 Auto X Codes w/ 2" Hanger/Shackle Drop Kit-38R w/Turbomaster,AFE, T500, Regulated Return, 6.0 Tranny Cooler, JWVB, 4"Exhaust, Hydra w/ Gearhead, PHP, and Powerstruck tunes, Powerstruck 180/100's Live Tuned by Powerstruck and then some!
dadada is offline
post #3 of 32 (permalink) Old 06-29-2013, 01:38 AM Thread Starter
That's what I'm thinking, I have a walbro but I can't find the right fittings to fit.. idk, might just go dual stockers..
post #4 of 32 (permalink) Old 06-29-2013, 02:07 AM
Rustbucket
data_engine's Avatar
I suggest doing the "Hutch" fuel tank mod. I am in process of doing it myself for a low fuel pressure problem. Never know what you'll find when you open up the fuel tank. Getting rid of the mixing chamber makes it worth it! See link below:
http://www.guzzle7pt3.com/hutch.php
"Lets Eat Grandma!"
"Lets Eat, Grandma!"
Commas Save Lives!
1999.5 F350 7.3 PSD Auto, 8" Lift, Nitto 38s, Hutch" Mod, AIH Delete, Fuel Pressure, Pyro & Boost Gauges, 4" Magnaflow turbo down, Riffraff Intake, Grand Rock 5" single stack, TS 6 Pos Chip
data_engine is offline
post #5 of 32 (permalink) Old 06-29-2013, 02:08 AM
dadada's Avatar
Check ebay,they sell a Walbro install kit and it will have the fittimgs you need.
dadada is offline
post #6 of 32 (permalink) Old 06-29-2013, 02:33 AM
^x2
1999 f350 7.3l
dp tuner 80econo flash
Mbrp-homemade stacks
Cold air intake
Gloshift gauges (marginal quality)
BB mod for 2 days (made things worse)
Fuel regulator upgrade
Wicked wheel / Turbo rebuild
3" leveling kit
07 Headlights/grill conversion
If it was the zombie apocalypse would you hop in you're 6.0 or 7.3?
Strokinstrong is offline
post #7 of 32 (permalink) Old 06-29-2013, 02:58 AM Thread Starter
I tried looking on eBay but I can't find it, you have a link?
post #8 of 32 (permalink) Old 06-29-2013, 05:12 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I would drop the tank and do the intank mods. More then likely thats your issue.
If you have not yet installed the Walbro I would return it and get a Genuine Bosch pump.
I went thru 4 Walbros in as many years. Not worth it...
Riffraff Diesel: Bosch Electric Fuel Pump
Joe
CSIPSD is offline
post #9 of 32 (permalink) Old 06-29-2013, 02:19 PM
dadada's Avatar
400-939 Walbro Install Installation Kit for GSL 391/392/393/394/395 Inline Pump
Go to ebay and try this.
dadada is offline
post #10 of 32 (permalink) Old 06-29-2013, 02:43 PM
CSIPSD's Avatar
Keep in mind the Walbro is NOT rated for Diesel... And WILL NOT LAST.
Joe
CSIPSD is offline
