Purchased Turbomaster Wastegate Controller - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-28-2013, 02:17 AM Thread Starter
01 SmokeChoke's Avatar
I hear these are pretty great. My unplugged stock actuator has about 25k on it now and seems it doesnt want to hold boost as well...
How does everyone like their Turbomaster Controllers? Any advice for the install? Id like to do it on the truck.
01 SmokeChoke is offline
post #2 of 7 (permalink) Old 06-28-2013, 12:24 PM
International Coal Roller
jbwaldrop88's Avatar
Re: Purchased Turbomaster Wastegate Controller
Make sure the big pin is inserted properly on the turbo, then crank it all the way shut and see where your boost is. You can back it off from there to dump at a specific boost load, I've seen them set to hold 25 lbs and they work great, I've also seen them cranked shut and left although we couldn't tell the boost load, maxed out a 30lb gauge before he ran out of pedal.I can say you can tell the difference on a chipped truck better. A PHP 140 tune and a turbo master will make a stock truck just nasty. On the install make sure you tie some floss or something similar onto the clip or else your gonna drop it and you will probably never find it.
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
post #3 of 7 (permalink) Old 06-28-2013, 11:22 PM
Village Idiot
southmike's Avatar
good tip on the floss..then just hit it with a lighter maybe..
southmike is offline
post #4 of 7 (permalink) Old 06-29-2013, 12:04 AM Thread Starter
thank you guys I look fwd to it.
post #5 of 7 (permalink) Old 06-29-2013, 12:22 AM
dadada's Avatar
You cant go wrong owning one.My truck will hit 35 psi and not blink an eye.Just play with setting it a little.Its very easy to adjust.
2001 F-250 4X4 SCSB 7.3 Auto X Codes w/ 2" Hanger/Shackle Drop Kit-38R w/Turbomaster,AFE, T500, Regulated Return, 6.0 Tranny Cooler, JWVB, 4"Exhaust, Hydra w/ Gearhead, PHP, and Powerstruck tunes, Powerstruck 180/100's Live Tuned by Powerstruck and then some!
dadada is offline
post #6 of 7 (permalink) Old 06-29-2013, 01:16 AM Thread Starter
thats pimp. my truck will snag 30-32 psi at lock up WOT but wont push above 30. I think the stock wastegate contorller is wearing out. I have been running it unplugged for a long time. Tired of wasting boost and power on the stock wastegate controller.
post #7 of 7 (permalink) Old 06-29-2013, 02:12 AM
dadada's Avatar
I tried running the same way for awhile.The Turbomaster actuator is awesome!
dadada is offline
