Need help with injector instillation?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 06-27-2013, 12:54 PM Thread Starter
7.3_geek_124's Avatar
I just put in a set of swamp 160/100 sticks in my 7.3 and I'm at the purging stage, and every time I prime it it shoots a lot of air and not much oil and once it's done purging fuel comes out of the back ports on only the injectors on #1 and #2.. This is my first injector stall but to me that doesn't seem right.. Anybody have any ideas?
Late model 99 ext cab - Exterior: 05 front end, 08 mirrors, 08 tail gate, 10 inch skyjacker lift on full springs, 22x13.50 moto metal 962's wrapped in 37" Toto mt's.
Engine: swamps 160/100 sticks, turbonetics turbo with a 63/91 comp wheel, gauges, riffraff ocr, riffraff intercooler boots, ts 6 pos chip.
7.3_geek_124 is offline
post #2 of 8 (permalink) Old 06-27-2013, 02:15 PM
the stryker god
Re: Need help with injector instillation??
Just jump the solenoid so you don't have power to the fuel pump or idm
bruce51d is offline
post #3 of 8 (permalink) Old 06-27-2013, 02:47 PM Thread Starter
thats what i have been currently doing, with the glow plugs out im jumping the solenoid to purge it, and for some reason i have some slight fuel coming out and not exactly sure why..
post #4 of 8 (permalink) Old 06-27-2013, 02:52 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
How to install injectors...
Remove valve covers
Remove back two injectors, wait 5 minutes
Remove remaining injectors
Remove glow plugs
Quickly clean cups with a rag or blow gun
Install new injectors.
Install valve covers with one or two bolts
Bump starter quickly, wait and repeat 2-3 times then bump it again for 10-15 seconds.
Install glow plugs, finish everything else and start.
Its not brain surgery.
Joe
CSIPSD is offline
post #5 of 8 (permalink) Old 06-27-2013, 04:16 PM Thread Starter
ya its a fairly easy install i just dont want to f*ck something up sense this is my first injector install im just trying to cover all the basics and ensure i didnt forget anything. And plus i also installed a turbonetics drop in turbo, ts 6 pos chip, frx, and a complete wiring harness because mine was shot to hell..
post #6 of 8 (permalink) Old 06-27-2013, 04:16 PM
OBS Stroker
Nodge's Avatar
Put the glow plugs in and start it. You've purged enough.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #7 of 8 (permalink) Old 06-27-2013, 04:24 PM
greenbeast's Avatar
Are you purging the system with no injectors in the bores? If so please refer to the steps Joe listed above to get you on the right track.
greenbeast is offline
post #8 of 8 (permalink) Old 06-27-2013, 05:24 PM Thread Starter
No I'm purging with the glow Plugs out And the injector harness disconnected
